Orphaned AttributeSet - Sketchline
Tiffany_Hayden_
Tiffany_Hayden_
Is there a way to find attributes that have been orphaned.
In my case the user can delete a sketchline and that sketchline has attributes attached to it but once the sketchline is deleted the attribute set changes to "Nothing" with the attribute still attached to the orphaned object. I've looked at the planar sketch and the part document. But I don't see an object that will help.
Tiffany Hayden
Accepted solutions (3)
WCrihfield
Hi @Tiffany_Hayden_.  If the attributes were within an AttributeSet, that was within the AttributeSets, that were attached to a SketchLine, then you deleted that SketchLine, then all the AttributeSets attached to it, as well as all the AttributeSet objects, and Attribute objects within those, would be deleted also.  But just in case I am not understanding the situation clearly, you can use the Document.AttributeManager property to access the main AttributeManager object, then use its powerful methods to attempt to find the attributes you are looking for.
SketchLine.AttributeSets
Wesley Crihfield
(Not an Autodesk Employee)
JelteDeJong
Maybe this can help you. This test rule will find the attribute sets that are not attached to an entity.
Dim doc As DrawingDocument = ThisDoc.Document
Dim attManager = doc.AttributeManager
Dim allsets As IEnumerable(Of AttributeSet) = doc.AttributeManager.FindAttributeSets().Cast(Of AttributeSet)
For Each attributeSet As AttributeSet In allsets
    Dim foundEntities As ObjectCollection = attManager.FindObjects(attributeSet.Name)
    If (foundEntities.Count = 0) Then
        MsgBox("Found attribute set without entities")
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Curtis_Waguespack
@Tiffany_Hayden_
I have often just used the PurgeAttributes method as part of creating attributes to clean up orphaned attributes as I go. This might or might not work for you depending upon how you're using the data.
example:
Sub Main
	' Check to make sure a sketch is open.
	If Not TypeOf ThisApplication.ActiveEditObject Is PlanarSketch Then
		MsgBox("A sketch must be active to use this tool.")
		Exit Sub
	Dim oCompDef As ComponentDefinition
	oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
	Dim oSketch As Sketch
	oSketch = ThisApplication.ActiveEditObject
	Dim oObjCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	Dim oSelectedLine As SketchEntity
	Do
		oSelectedLine = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "Select a Sketch Line.")
		oObjCol.Add(oSelectedLine)
	Loop While oSelectedLine Is Nothing
	For Each oObject As Object In oObjCol
		If TypeName(oObject) = "SketchLine" Then
			Dim oSketchEntity As SketchEntity = oObject
			Call CreateAttrib(oSketchEntity, oSketch.Name & "_Atttributes", oSketch.Name & "_Test", "hello world")
	Next
End Sub
Public Sub CreateAttrib(oSketchEntity As SketchEntity, sAttribSetName As String, sAttribName As String, sValue As String)
	Dim oAttrSet As AttributeSet
	Dim oAttrib As Inventor.Attribute
	ThisDoc.Document.AttributeManager.PurgeAttributeSets(sAttribSetName)
	Try
		oAttrSet = oSketchEntity.AttributeSets.Item(sAttribSetName)
		Logger.Info("Attr Set Found")
	Catch
		oAttrSet = oSketchEntity.AttributeSets.Add(sAttribSetName)
		Logger.Info("Attr Set Created")
	End Try
	Try
		oAttrib = oAttrSet.Item(sAttribName)
		Logger.Info("Attrib Found")
	Catch
		oAttrib = oAttrSet.Add(sAttribName, ValueTypeEnum.kStringType, sValue)
		Logger.Info("Attrib Created")
	End Try
	oAttrib.Value = sValue
End Sub
Tiffany_Hayden_
Thanks! @Curtis_Waguespack  @JelteDeJong  @WCrihfield I think the missing piece for me was the Attrubute Manager. I have Nifty Attributes installed and that application could see it so I knew there had to be a way! Thanks so much for all your help!
Tiffany Hayden
