ordinate Dimensions using sketch points
Mario-Villada
Mario-Villada
Hi All,
I  am trying to add Ordinate dimensions  using scketch points, my code spits out an "Unspecified error" when I try to use one sketch point as a geometry intent to create origin indicator method in the drawing view. here is some code:
{code}
Dim oDV as DrawingView
Dim oSheet asSheet
Dim oGIntent asGeometryIntent
Dim Sktch asDrawingSketch
Dim sktP assketchPoint
Dim oPt asPoint2d
Dim TG as transientGeometry
  oPt := oDV.ModelToDrawingViewSpace(Inv.TransientGeometry.CreatePoint(0,0,0));
  Sktch := oDV.Sketches.Add;
  Sktch.Edit;
  sktP:= Sktch.SketchPoints.Add(oPt,false);
  oPt := oDV.ModelToDrawingViewSpace(Inv.TransientGeometry.CreatePoint(100,52.5,0));
  sktch.ExitEdit;
  oGIntent := oSheet.CreateGeometryIntent(Sktch.SketchPoints.item[1],emptyparam);
  oDV.CreateOriginIndicator(oGIntent); // Here is when the error happens
{code}
I also tried to set
sktP.ConnectionPoint:=true;
sktP.InsertionPoint :=true;
but no luck.
I also noticed that the points created are not visible after sktch.ExitEdit, but  i don't see a way to make them visible.
Any Ideas?
Mario.
Mario-Villada
Nevermind, I found a workoround by addng lines to the sketch and using the start point as geometry to crate the geometry intent.
Although I think there is a contradiction in the Inventor programming help file, since it says that  Valid input objects for the geometry parameter in Sheet.CreateGeometryIntent Method are sketch entities from a sheet sketch. and as far as I know a sketch point IS as sketch entity from a sheet sketch.
