OrderProcessorSettings.exe
Bull_Frog_5299
Bull_Frog_5299
I am tinkering with the ETO Server Batch Processing and ETO Order Processor (2015).  I successfully ran an order throught batch processing with the command line interface.  Now I'm trying to configure the Order Processor Settings.  I am unclear on what some of the fields/windows are expecting as input.  I have not found an example or tutorial anywhere.  In the Order Processor Settings Window, there is a "For each order.... window".  What goes in this box?  I would prefer to hand the Job Processor a complete Task File (already in the expected xml format).  Any guidance/suggestions/advice is much appreciated.  I don't know how to proceed without some help.
wayne.brill
I attached an old document I found. (sent this through email also) Most of it still applies to the current release of ETO.
This post should probably have been made on the ETO customization forum:
http://forums.autodesk.com/t5/inventor-engineer-to-order/bd-p/184
Here is more information about this. (also sent through email)
Task = a file containing instructions to InventorETOServer
Order = a file containing the metadata read by the ETO rules which then act on them to build a model, create outputs, etc.
The order processor creates the task files.
The input files are the Order files.
The order processor is able to include in the task files it builds the path to the specific order file to be processed, along with instructions like renderself, set the rule ‘createdrawings’ to true, etc.
(The path to the specific order file, to be processed in the task file, built by the order processor needs to be set in Order Processor Settings).
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
