Open unsaved document (VB.net/VBA)
Eyal.Admon
Eyal.Admon
TRLD: How can i open a part that was ceated in an assembly bebore saving it?
when i create a new part in an assembly with the create button, the file is not created untill i save the part for the first time, so using " oDoc = thisapplication.Documents.open(file path) " won't work since no path exists.
Using the right click button, i can open the part and edit it. how can i open it using VBA/VB.net code?
AlexKorzun
To make document visible, you just add a view of it. Similar to:
    Dim doc As PartDocument
    Set doc = ThisApplication.Documents(ThisApplication.Documents.Count)
    Call doc.Views.Add
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
Eyal.Admon
Thank you!
I think you misunderstood  what i wanted to do but your comment helped a lot.
this is what i needed (VBA):
 Set oDoc = ThisApplication.ActiveDocument
 Set sSet = oDoc.SelectSet
 Set oDoc2 = sSet.Item(1).Definition.Document
 oDoc2.Views.Add
