Open the BOM using vb.net
Is there a way to open the BOM using vb.net?
sgwilliams
Just a friendly note on asking questions here. You may want to explain yourself a little better. A vague question will most generally be ignored. Think about what you're trying to accomplish then post that along with the question that is stopping you from moving forward.
Yes, I know for a fact that you can import and export BOM data. How you go about doing that is cannot be answered until we know what it is that you're trying to accomplish.
Work Station : Custom built, Liquid Cooled, Asus Pro WS X570-ACE Motherboard; AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor; ASUS TUF Gaming NVIDIA GeForce RTX 3060 V2 OC Edition Video Card; 32 GB CORSAIR Dominator Platinum DDR4-2132 Memory ; Samsung 850 EVO 1TB SSD Drive.
xiaodong_liang
Autodesk Support
Autodesk Support
I agree with sgwilliams that it will be more helpful if you could clarify your questions in detail.
If you are looking for hot to get started with BOM API, you could refer to the API help document, there is a topic [Bill of Materials] where introduces the related APIs and demo codes.
In case you have not known, API document typically locates at
C:\Program Files\Autodesk\Inventor 2016\Local Help\admapi_20_0.chm
This is what I’m trying to accomplish (Link Below). I started this thread because I marked the other as solved but after needed a little more help. I noticed if it’s marked as solved and a longer thread then some people will not read to the end and see that there’s another question. I would appreciate any help that you guys might be able to give. Thanks.
http://forums.autodesk.com/t5/inventor-customization/bom-configurations-using-ilogic/m-p/6493384
adam.nagy
Autodesk Support
Autodesk Support
It seems in the meantime @frederic.vandenplas managed to help you out 🙂
Thanks Frederic!
Adam Nagy
Autodesk Platform Services
