open text file and search for text
martinhoos
Message 1 of 8
martinhoos
i dont know how to do... i like to find text in an text file.
The idea:  rund the rule and place there a text. the rule open the text file and search for the text.
is there anyone who can help me?
Regards Martin
Replies (7)
Message 2 of 8
martinhoos
Like the pic:
Message 3 of 8
theo.bot
You can use the "System.IO.File.Readlines" to go thru the text. Here is a small sample
'____Open and read a text file line by line_______________________
Dim oFind As String
Dim Line As String
Dim I As Integer
oFind = InputBox("Enter text", "Search text", "")
If oFind <> "" Then
	For Each Line In System.IO.File.ReadLines("C:\Users\theob\Downloads\debug.log")
		If Line.Contains(oFind)Then
			Logger.Info("Text found at Line" &  I)
		I=I+1
	Next
Else
	MessageBox.Show("No search string provided")
Message 4 of 8
martinhoos
Thank you for the reply...
i do not have many experience with ilogic
As i understand your code, the line Logger.Info will highlight the text.
I changed the the path:
to:
C:\Users\tb1\Desktop\user.log
But nothing will happend.
After that i put in the line:
MessageBox.Show("Text found at Line" & I)
 i get the result:
Text found at Line574015
What is wrong?
Message 5 of 8
theo.bot
I'm not sure what you want to do next after you found the text in your document. So the code that i provided read every line and returns the linenumber. Your messagebox does the same. it simply returns the line number. But you can do a lot of other things, depending on what your goal is. You can take the full line text or a part of it and reuse it in a property or text object in inventor. So if you find the text what is your next step that you want to take.
Message 6 of 8
martinhoos
The next step ... mhhhh is it possible to get the path above? The beginning of the path is everytime the same -> V:\inventor-5
If you get the path is it possible to open the os (explorer) folder?
There is one restriction:  If the text found more than one time - a message shoult be up.
Thank you very much Theo
Message 7 of 8
theo.bot
This could be a start (only change the file path in the code):
Dim oFind,oFile, Line, oPath As String
Dim i,j As Integer
Dim oFound As Boolean
j=0
oFound = False
oFind = InputBox("Enter text", "Search text", "V:\inventor-5")
'use hardcoded path
oFile = "C:\Users\theob\Downloads\debug.log"
If oFind <> "" Then
	For Each Line In System.IO.File.ReadLines(oFile)
		If Line.Contains(oFind) And oFound = False Then
			oPath = Right(Line, Len(Line) -Line.IndexOf(oFind))
			Logger.Info("Text found at Line" & i)
			oFound = True
			j=1
		ElseIf Line.Contains(oFind) And oFound = True Then
			j = j + 1
			Logger.Info("Text found at Multiple Lines!")
		i=i+1
	Next
Else
If oFound = True And j=1 Then
	Process.Start("explorer.exe", oPath)
ElseIf oFound = True And j>1 Then
	MessageBox.Show("Found " & j & " lines containing the text: " & oFind)
Else
	MessageBox.Show("Text """ & oFind & """ not found in text.")
Message 8 of 8
martinhoos
Theo thank you very much....
The user documents explorer opend NOT the explorer with the V:\ path
The V:\ path in the text file is different.... only the beginning is equal  ->  v:\1-inventor
The Text file is created with:  dir v:\inventor-5\*.* /s > user.txt
for example:
In the text file are thousands of entries
