Open Projects location
wowrs1608
wowrs1608
I am following this to open Projects Location folder https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/vb-net-get-project-file-path/td-p/80...
But it only opens my Documents folder, not the the folder specified under the Get Started/Projets/Location item.
Which option I should choose?
Inventor 2022 +vb.net.
Cheers,
Pete
basautomationservices
There is a difference between the project file location and the project workspace location. I see both answers in the thread you linked. Did you try both options?
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Michael.Navara
I don't recommend you to use undocumented FileLocations property of Application object. Clear solution is to use ActiveDesignProject. Another issue may be in explorer.exe arguments
Here is short sample
Dim activeProject As DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject
Dim location = System.IO.Path.GetDirectoryName(activeProject.FullFileName)
Logger.Debug(location)
Dim args = String.Format("/e,/root,""{0}""", location)
Logger.Debug(args)
Process.Start("explorer.exe", args)
wowrs1608
I have tried both FileOptions & FileLocations.
I'll use the ActiveDesignProject.
wowrs1608
Thank you very much. This one worked.
