Open part with iLogic
JorisSteurs1246
Message 1 of 18
JorisSteurs1246
I have the code below to open a part that's gets his name from a multivalue text parameter.
The partnames are collected from the assembly components.
I could not get these names with .ipt extension , so I have to add this myself as you can see in the code below.
It works but is not perfect and will fail when more than 9 the same occurrences are present in the assembly.
Next problem is that to open the file I have to define also the complete path of that file.
This is also a problem , because Inventor should be able to find the parts anywhere in the workspace... to often the code will fail otherwise.
Does anyone has any suggestions to improve the code below?
Thank you in advance
PS: don't worry about the messageboxes popping up, they are just acting as a logger  for the time being
'get user input
oSelection = Parameter("ActiveParts")
'catch null selection
If oSelection = "" Then
    Return 'exit rule
Else
    'set parameter value
    Parameter("ActiveParts") = oSelection
Dim doc As Document = ThisApplication.ActiveDocument
'provide user feedback
MessageBox.Show("You selected: " & oSelection, "iLogic")
NewName = Left(oSelection,(Len(oSelection)-2))' NOT GOOD!!, if more then 9 occurences in the assembly this will fail
MessageBox.Show("I found variable: " & NewName , "Info")
oFullFileName = (NewName & ".ipt")
MessageBox.Show("I found variable: " & oFullFileName , "Info")
oPath = ThisDoc.WorkspacePath()
MessageBox.Show("I found variable: " & oPath , "Info")
ThisDoc.Launch(oPath & "\parts\S_MountingPlates\S_MountingPlates_L\" & oFullFileName) ' NoT Good!!! location can change, 'Inventor has to search everywhere in  workspace not only the given location.
Replies (17)
Message 2 of 18
Owner2229
Hi, I assume the parts you're trying to open are all placed in the assembly, right?
If so, then you can use this code below. For some operations you don't even need to open the part (like reading/changing iProperties and Parameters).
Ussage:
1) Run the rule
2) Select first component
3) Select next component and continue as long as you want
4) Press Esc to stop selecting
5) The rule will run
Sub Main()
   Dim oDoc As Document
   oDoc = ThisApplication.ActiveDocument
   Dim comps As ObjectCollection
   Dim comp As ComponentOccurrence
   oDoc.SelectSet.Clear
   comps = ThisApplication.TransientObjects.CreateObjectCollection
   While True
      comp = ThisApplication.CommandManager.Pick(
      SelectionFilterEnum.kAssemblyLeafOccurrenceFilter,
      "Select Part(s)")
      ' If nothing gets selected then we're done
      If IsNothing(comp) Then Exit While
      comps.Add(comp)
   End While
   ' If there are selected components we can do something
   If comps.count = 0 Then Exit Sub
   Dim aDoc As DocumentsEnumerator
   aDoc = oDoc.AllReferencedDocuments
   Dim iDoc As Document
   Dim cName As String
   Dim cTS As String
   Dim sTS As String
   Dim FNP As Long
   Dim cFNP As Long
   Dim docFN As String
   For Each iDoc In aDoc
      sTS = iDoc.FullFileName
      FNP = InStrRev(sTS, "\", - 1)
      docFN = Mid(sTS, FNP + 1, Len(sTS) - FNP)
      For Each comp In comps
          cTS = comp.Name
	  cFNP = InStrRev(cTS, ":", - 1)
	  cName = Left(cTS, cFNP - 1)
	  If cName = Left(docFN, Len(docFN)-4) Then
	      MsgBox("You have selected this part:" & vbLf & sTS)
	      'Here is how to set iProperties in each of the selected parts in assembly
              'iProperties.Value(docFN, "Custom", "Mark") = "this part is now marked"
	      'Here is how to open the part
	      'ThisApplication.Documents.Open(sTS, True)
      Next
   Next
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 18
JorisSteurs1246
Hi Thanks for having a look into this.
I tried your code and it works nice , but it is not exactly what I'm trying to do here.
Yes the part that I want to open is always available in the assembly that holds the rule.
Your code lets you pick objects and open them afterwards.
My selection comes from text stored in the multivalue list .
I have multivalue list  ( "partA:1","partB:1","partC:1","partD:1") that collected all active occurrences in the assembly with another rule.
So What I need to do is just get  "partA:1" and open it as "partA.ipt" from where ever it might be saved in the active workspace.
Better would be if the multivalue list would collect the correct file names from every leaf occurence , but  I dind't find any documentation about this.
Message 4 of 18
Owner2229
Hi, to get the full file name from Occurence you can use this:
'Let's say we have occurence "oOcc" from AllLeafOccurences
Dim aDoc As Document = oOcc.Definition.Document
Dim FullFileName As String = aDoc.FullFileName
To strip "partA:1" to "partA" you can use this:
Dim text As String = "partA:1"
Dim FNP As Integer = InstrRev(text, ":", -1)
Dim PartName As String = Left(text, FNP - 1)
We can then make these to work together eg. as this:
Dim FNP0 As Integer = InstRev(text, ":", -1)
Dim NewDoc As String = Left(text, FNP0 - 1) Dim sTS As String Dim FNP As Integer Dim FName As String Dim oAsmCompDef As ComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition Dim oOcc As ComponentOccurrence For Each oOcc In oAsmCompDef.Occurrences sTS = oOcc.Name FNP = InStrRev(sTS, ":", -1) FName = Microsoft.VisualBasic.Left(sTS, FNP - 1) If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then FName = FName & ".ipt" ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then FName = FName & ".iam" End If If FName = NewDoc Then oDoc = oOcc.Definition.Document
ThisApplication.Documents.Open(oDoc, True) End If Next
Mike
Message 5 of 18
JorisSteurs1246
I tried the code that you suggessted can't get it to work, because it handles with occurences and not with my string from the multivalue.
Maybe somethign can be done here instead,
Below is the code I use to get the occurneces name into the Multivalue  parameter.
I've been trying very hard to get the full file name as a string into this parameter but no succes.
If I could populate my parameter with values like "PartA.ipt" and not "PartA:1 then the other code  to open the selected file would be fairly simple.
'check this file is an assembly
If doc.DocumentType = kPartDocumentObject Then
    MessageBox.Show("This rule can only be run in an assembly file!", "ERROR")
    Return
    ' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
Dim oAsmDef As AssemblyComponentDefinition
    oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
Dim oLeafOccs As ComponentOccurrencesEnumerator
    oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
Dim NameList As New ArrayList()
'Iterate through the occurrences And collect the name.
For Each oOcc In oLeafOccs
oPartName = (oOcc.Name )
If Component.IsActive(oPartName) = True Then
    NameList.add(oPartName)
    Else
Next
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
    'Setting an userParameter as text parameter
Try
    otester = oMyParameter.Item("ActiveParts")
Catch
    oInsulationType=oMyParameter.AddByValue("ActiveParts", "", UnitsTypeEnum.kTextUnits)
    'make parameter a multivalue list parameter
    MultiValue.SetList("ActiveParts", "NoData1", "NoData2", "NoData3")
End Try
'set list parameter to use array list
MultiValue.List("ActiveParts") = NameList
Dim ValuesL As Integer
ValuesL = Len("ActiveParts")
Parameter("CountActiveParts") = ValuesL
Message 6 of 18
Owner2229
Alright then, here is the first rule (to populate the parameter):
' Check this file is an assembly
If Not doc.DocumentType = kAssemblyDocumentObject Then
    Return
' Iterate through the occurrences And collect the name.
Dim oPartName As String For Each oOcc In oLeafOccs oPartName = (oOcc.Name) If Component.IsActive(oPartName) = True Then
Dim FNP As Integer = InstrRev(oPartName, ":", -1)
Dim FName As String = Left(oPartName, FNP - 1)
       End If
NameList.add(FName) Else End If Next oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters ' Setting an userParameter as text parameter Try otester = oMyParameter.Item("ActiveParts") Catch oInsulationType=oMyParameter.AddByValue("ActiveParts", "", UnitsTypeEnum.kTextUnits) ' Make parameter a multivalue list parameter MultiValue.SetList("ActiveParts", "NoData1", "NoData2", "NoData3") End Try ' Set list parameter to use array list MultiValue.List("ActiveParts") = NameList Dim ValuesL As Integer ValuesL = Len("ActiveParts") Parameter("CountActiveParts") = ValuesL
And here is your second rule (to open the parts):
' Get user input
oSelection As ArrayList = Parameter("ActiveParts")
' Catch null selection
If oSelection.Count = 0 Then
    Return ' Exit rule
' Go throught the selection
Dim oDoc As Document Dim sTS As String Dim FNP As Integer Dim FName As String Dim item As String For Each oOcc In oAsmCompDef.Occurrences sTS = oOcc.Name FNP = InStrRev(sTS, ":", -1) FName = Microsoft.VisualBasic.Left(sTS, FNP - 1) If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then FName = FName & ".ipt" ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then FName = FName & ".iam" End If
For Each item in oSelection If FName = item Then oDoc = oOcc.Definition.Document ThisApplication.Documents.Open(oDoc, True) End If Next Next
Mike
Message 7 of 18
JorisSteurs1246
Hi Mike,
The first rule works beatifull 🙂
But the second rule gives an error saying  " oSelection is not declared"
i try to solve it like this by putting "Dim"
Dim oSelection As ArrayList = Parameter("ActiveParts")
 But then I get the following error
Error in rule: OpenPart3, in document: S_BeamAssy_L.iam
Unable to cast object of type 'System.String' to type 'System.Collections.ArrayList'.
Message 8 of 18
Owner2229
Ah, sorry, my fault. Here is the correction:
' Get user input
Dim oSelection As ArrayList = MultiValue.List("ActiveParts")
    Return ' Exit rule
Dim sTS As String
Dim FNP As Integer
Dim FName As String
Dim item As String
    sTS = oOcc.Name
    Next
Next
Mike
Message 9 of 18
JorisSteurs1246
Did you only add " Dim" in the front?
This I tried myself but didn't work .
your latest code gives the following error.
Unable to cast COM object of type 'System.__ComObject' to class type 'System.String'. Instances of types that represent COM components cannot be cast to types that do not represent COM components; however they can be cast to interfaces as long as the underlying COM component supports QueryInterface calls for the IID of the interface.
Message 10 of 18
Owner2229
Hi, try this one. I have tested it and it should work. I have hightlighted the corrections for you.
' Get user input
    Return ' Exit rule
Dim sTS As String
Dim FNP As Integer
Dim FName As String
Dim item As String
    sTS = oOcc.Name
    For Each item In oSelection
            ThisApplication.Documents.Open(oDoc.FullFileName, True)
    Next
Next
Mike
Message 11 of 18
JorisSteurs1246
Hi Mike
No more errors, works nice 🙂
Just that it opens every part from the array, while its was my goal to open only the selected part from the array.
I assume this is a minor change?
Joris
Message 12 of 18
Owner2229
I'm not realy sure how you have done your selection in the first place...
Mike
Message 13 of 18
JorisSteurs1246
Hi Mike
The multivalue parameter wil be placed on an ilogic form as a dropdown box
Under this dropdown box comes a button to trigger the rule that will open the part that is selected in the dropdown box.
I've to do so because my assembly has a big amount of suppressed parts,
so it is too difficult to search a specific part from the browser itself.
Message 14 of 18
Owner2229
Alright then, here you go:
' Get user input
Dim oSelection As String = Parameter("ActiveParts")
    Return ' Exit rule
Dim sTS As String
Dim FNP As Integer
Dim FName As String
    sTS = oOcc.Name
    If FName = oSelection Then
Next
Mike
Message 15 of 18
JorisSteurs1246
The count on the oSelection string gave an error , but I've managed to make a walk around this problem.
Maybe not the most elegant solution , but anyhow 😉
Here is the working code
'check number of entries in the multi value param.
' Get user input
' Catch null selection or empty multi value param.
If ValuesL >= 1 Then
    MessageBox.Show("No FileName found to open", "ERROR")
    Else
    Else
Dim sTS As String
Dim FNP As Integer
Dim FName As String
    sTS = oOcc.Name
Next
Message 16 of 18
JorisSteurs1246
Hi Mike,
If its OK for you to re-post the working code I came up with then i can accept your post as solution.
Anyhow its 99.5 percent your code and skill, so you definitely deserve the credits for it. 🙂
Thanks for all the effort, it is really appreciated.
Joris
Message 17 of 18
Owner2229
Hi, maybe more like this 😉
You don't need to use the "Len("ActiveParts")" as you don't care if there are any parts in the parameter.
You only need to know if something is selected. Btw. shouldn't we clear the selection after we're done? So it won't cause any trubles when the rule is runed again.
' Get user input
If oSelection = vbNullString Then
Return ' Exit rule End If ' Go throught the selection Dim oAsmCompDef As ComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition Dim oOcc As ComponentOccurrence Dim oDoc As Document Dim sTS As String Dim FNP As Integer Dim FName As String For Each oOcc In oAsmCompDef.Occurrences sTS = oOcc.Name FNP = InStrRev(sTS, ":", -1) FName = Microsoft.VisualBasic.Left(sTS, FNP - 1) If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then FName = FName & ".ipt" ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then FName = FName & ".iam" End If If FName = oSelection Then oDoc = oOcc.Definition.Document ThisApplication.Documents.Open(oDoc.FullFileName, True) End If Next
' Clear the selection
Parameter("ActiveParts") = ""
Mike
Message 18 of 18
JorisSteurs1246
Hi Mike,
Yes you are correct about the selection , the way you did it is much better.
About clearing the selection I would keep this for myself as an option.
If you run the command a second time with the same selection , Inventor will just show you the window that was already open.
Also in my userform I can see still the filename of the latest file that was opened, so its a little more easy if you are cycling trough opening the parts of your assembly.
Nevertheless , again great thanks for helping  me out
Joris
