open / load Assembly from filesystem
How can i open an existing assembly or part file (stored on a local drive) through the API? It should be possible, but i cannot find the required method calls in the API-documentation.
Win7 64bit, Autodesk Inventor 2011
Mike.Wohletz
In VBA
Public Sub openitem()
Dim strPath As String
strPath = "c:\jobs\widget.ipt"
Dim invDoc As Document
Set invDoc = ThisApplication.Documents.Open(strPath, True)
End Sub
