Open IDW with Apprentice.OpenWithOptions method HELP
Raider_71
Raider_71
Hi I have created a batch printer using VB.net but are having issues when some of the idw files have unresolved references and I get HRESULT errors etc and then crash. I use Apprentice server and have noticed that there is a method OpenwithOptions that can be used. I have tried specifying SkipallunresolvedFiles in a Namevaluemap but with no luck. See code:
Dim oDocOpenOptions As NameValueMap
oDocOpenOptions = oApprentice2.TransientObjects.CreateNameValueMap
oDocOpenOptions.Add("SkipAllUnresolvedFiles", True)
oApprDoc = oApprentice2.OpenWithOptions(lstBox1.Items.Item(i), oDocOpenOptions)
Dim oApprDrgPrintMgr As ApprenticeDrawingPrintManager
oApprDrgPrintMgr = oApprDoc.PrintManager
Any ideas?
Pieter
tech
I would also know about this. Having the same issue. Can do it with an Inventor App object but as soon as you use Apprentice the .OpenwithOptions dont seem to work.
philippe.leefsma
Unfortunately in case of "OpenWithOptions" and the "SkipAllUnresolvedFiles" options, Apprentice doesn't support it yet. We have logged a wish about that to our engineering team but it has not been implemented yet. I guess there is no workaround while using Apprentice at the moment.
Sorry for the bad news.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
