Open IDF in VBA
We were in the prodcess of importing IDF files but this can take 20 to 30 minutes per file in some cases and we have many files. I first tried the Task Scheduler but it would not handle the IDF files ( the IDF file option is available on Routed system or Pro). So I've turned my attention to VBA.
I can use the ThisApplication.Documents.Open and pass it the file string but the process stops at the Dialog where you specify the results as a Part or an Assembly.
Is there a method to specify the option in VBA? Would .Net be possible?
G
