Open fusion file as reference model
Chris-strickland
Chris-strickland
I have the desktop connector set up and can import fusion files to inventor through the user interface - great. When I do this manually I get the two options: Reference or Convert.
I can open a .fusionDesign file using the API:
Sub openAndTranslate()
    Set invApp = ThisApplication
    Dim oDoc As Document
    Set oDoc = invApp.Documents.Open("C:\...\part.FusionDesign")
 End Sub
This converts the file into an inventor solid model. I'd like to make a referenced/ linked file.
Can I access the import options for this process through the API?
Should I be using: Call ThisApplication.Documents.OpenWithOptions() instead?
Alternatively, can I translate the file using the translation add-in object (ThisApplication.ApplicationAddIns.ItemById(sClientID)) I have the ClientID for the fusion translator, but Can't find any documented options - what settings are available there?
JhoelForshav
Hi @Chris-strickland
It doesn't seem like I have the necessary addin to import fusion files at all, so I can't really test this, but I think it's worth a try to create an assembly and import the file by creating a ImportedGenericComponentDefinition. That object has a property called ReferenceModel which sounds like what you're looking for.
If you have an assembly open and you want to do this through iLogic the rule would look something like this then:
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAssyCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
'Create the ImportedGenericComponentDefinition based on a file
Dim oImportedGenericCompDef As ImportedGenericComponentDefinition = oAssyCompDef.ImportedComponents.CreateDefinition( _
"C:\testfile.f3d")
'Set the ReferenceModel to associatively import the file
'True is the default value
oImportedGenericCompDef.ReferenceModel = True
'Import the file to assembly
Dim oImportedComp As ImportedComponent = oAssyCompDef.ImportedComponents.Add(oImportedGenericCompDef)
As I said. I can't try it myself because I cant even open fusion files in inventor so I can't really say if it works or not 🙂
Chris-strickland
Yes thanks Jhoel,
I think the oImportedGenericCompDef.ReferenceModel = True is the key.
I found/adapted the following from the API help: https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-6D1F335F-7680-4F7D-9A26-F141DCD1B1BD
Sub AssociativelyImportToPartSample()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.Documents.Add(kPartDocumentObject)
    Dim oPartCompDef As PartComponentDefinition
    Set oPartCompDef = oDoc.ComponentDefinition
    ' Create the ImportedGenericComponentDefinition bases on an fusion file
    Set oImportedGenericCompDef = oPartCompDef.ReferenceComponents.ImportedComponents.CreateDefinition("C\...Part.fusiondesign")
    ' Set the ReferenceModel to associatively import the Fusion file, set this property to False will just convert
    oImportedGenericCompDef.IncludeAll
    ' Import the file
    Set oImportedComp = oPartCompDef.ReferenceComponents.ImportedComponents.Add(oImportedGenericCompDef)
End Sub
This imports a fusion design file into a part file as reference/linked. I know it says that the defult is to import as reference, but I don't think that is the case with oDoc = invApp.Documents.Open("part.fusiondesign") when I tried that it imports as a converted file - the previous user setting does not make any difference.
