Open File location - within Inventor
andrew_canfield
Message 1 of 8
andrew_canfield
Hello
Thankyou for this code which will open the file location using Windows File Explorer.
How can it be tweaked to open the file location within the Inventor 'File Explorer' window*?
Sub Main()
	'Copy the path of the current model to oPath
	oPath = ThisDoc.Path
	'[Now we want to open this path with Explorer.exe. We can use the Process.Start function for this.
	'The Start function needs to know which application it'll launch and what arguments it requires.
	']oPath is already a string but the Start function needs this: [Start(Explorer.exe "C:/Filepath/")]
	Dim Proc As String = "Explorer.exe"
	Dim Args As String = ControlChars.Quote & oPath & ControlChars.Quote
	Process.Start(Proc, Args)
End Sub
Inventor 'File Explorer' window - this one...
Regards
Andrew
Replies (7)
Message 2 of 8
Ralf_Krieg
Hello
Try this one
Sub Main()
	Dim oFileDlg As Inventor.FileDialog
	Call ThisApplication.CreateFileDialog(oFileDlg)
    oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
    oFileDlg.FilterIndex = 1
    oFileDlg.DialogTitle = "Open File Test"
    oFileDlg.InitialDirectory = oPath
    oFileDlg.CancelError = True
    Try
    	oFileDlg.ShowOpen
		MsgBox ("File " & oFileDlg.FileName & " was selected.")
    Catch
        MsgBox ("User cancelled out of dialog")
    End Try
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 8
andrew_canfield
That was quick! Many Thanks
Message 4 of 8
andrew_canfield
Is another tweak possible?
The original request to open a folder from Inventor works faster than opening the folder in explorer but I've only found copy & paste the next useful action from the open window.
I'm thinking an ilogic rule to 'Place from current folder' would be excellent - where the current folder is where the current assembly has been saved.
Message 5 of 8
Ralf_Krieg
Hello
This one starts the open dialog from the folder of the current document and uses the selected part/assembly for the place component command.
Sub Main()
    oFileDlg.DialogTitle = "Place Component"
	oFileDlg.InsertMode=True
    Try
    	oFileDlg.ShowOpen
		'MsgBox ("File " & oFileDlg.FileName & " was selected.")
		ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oFileDlg.FileName)
		ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
    Catch
        MsgBox ("User canceled out of dialog")
    End Try
End Sub
R. Krieg
RKW Solutions
Message 6 of 8
andrew_canfield
Amazing - thanks again.
Message 7 of 8
andrew_canfield
Amazing - many thanks.
Message 8 of 8
quangnguyenJ8ZMH
Hello @Ralf_Krieg
thank for your code , it  works,
but i want ilogic that have scenario as below,
1, working in assembly file,
2, select a part then run ilogic and it will open folder location and we can select replaced part
3, ole part will be replaced by new part and keep the constraint.
it look like "replace" command in Inventor but i have to right click many time
by the way, in excel we can insert a macro by using record, how to use it in Inventor
many thanks
