Open excel which is in the same folder as an assembly
tomislav.peran
Message 1 of 8
tomislav.peran
I would like to open the excell file, via rule of course,  but without specifying the path.
I will keep an excell sheet in the same folder as my assembly.
I think this is possible so if anyone knows please let me know.
Tom
Replies (7)
Message 2 of 8
basautomationservices
Will you know the filename of the excel? Then it is possible. For example:
Dim filename As String = "test.xlsx"
Dim thisFilename As String = ThisDoc.Document.FullFileName
Dim folder As String = System.IO.Path.GetDirectoryName(thisFilename)
Dim files As List(Of String) = System.IO.Directory.GetFiles(folder).ToList()
Dim excelFile = files.FirstOrDefault(Function(x) System.IO.Path.GetFileName(x) = filename)
If excelFile <> Nothing Then
	GoExcel.Open(excelFile)
You could also look for all files with the extension .xlsx, but in this case I assumed you would know the name of the excel, here "test.xlsx". I noticed that in inventor 2021, using the GoExcel errors if there is not a sheet called Sheet1 in the workbook.
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Message 3 of 8
tomislav.peran
Hi basautomationservices,
Thanks for your reply. I tried the code but it does not open it. The only thing that works for me now is if I enter location like here:
Dim objExcel = CreateObject("Excel.Application")
Dim objWorkbook = objExcel.Workbooks.Open("Location\Tom_Excel.xlsx")
objExcel.Application.Visible = True
 Anything else does not seem to work,
Tom
Message 4 of 8
The application probably opens but is not visible:
	GoExcel.Open(excelFile, "Sheet1")
	excelApp = GoExcel.Application
	excelApp.Visible =True
	GoExcel.CellValue("A1") = "Test"
	GoExcel.Save
	' GoExcel.Close
Message 5 of 8
tomislav.peran
I have entered the new code but then I get error on line 10.
De objectvariabele of With block-variabele is niet ingesteld.
Translated:
The object variable or With block variable is not set.
Unfortunatelly no luck as well,
Tom
Message 6 of 8
If you just want to open the file and combine yours and mine you can use this.
	Dim objWorkbook = objExcel.Workbooks.Open(excelFile)
Do you also want to write/read cells from this sheet?
Message 7 of 8
tomislav.peran
Hi Basautomation,
Yes, this works. Thank you a lot!
Tom
Message 8 of 8
tomislav.peran
"Do you also want to write/read cells from this sheet?"
Sorry, I did not see this question.  I write some parameters into it, yes, via my rules . So far that is going oke.
But sometimes I have issues with excell document because it turns into "read only" by itself. I am not sure why but I think it has something to do with Inventor itself.
Tom
