Open drawing skip user input
CAD-e-Shack
CAD-e-Shack
I'm using the following code to open a drawing:
Set doc = ThisApplication.Documents.Open(Archive, True)
and this code to close the drawing
ThisApplication.ActiveDocument.Close True
The close command skips the typical user input that is required but for some reason I don't find the option for when the drawing is opened.
The drawing must open in order that it can update the changes that are being made to it by the code (so I can't insert "false" into the open command).
However, because many of the drawings are stored in vault I get the prompt whether or not to check the drawing out.
Is there a way I can automatically select one of the options (attachment) without the user selecting it each time?
ps
I also am using the command
ThisApplication.SilentOperation = True
throughout the code
jdkriek
My first idea would be to programatically set the Vault dialog options that you can set manually via the UI
But the only thing I could find was PromptMessageRestrictionsEnum
Btw, It's been asked many times, but with no responces:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Dialog-suppression-for-check-in-on-fil...
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Vault-Messages-in-Inventor/m-p/1509481...
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
CAD-e-Shack
Ultimately it's not the best solution, but with the options that I've been given, it's the closest that I have found.
Thanks.
jdkriek
I know and given the fact that no one has come up with a solution since 2005 (Vault 4.0) - anything is better than nothing 😉
Jonathan D. Kriek
Burnit87
im doing some automated dxf exports for sheet metal, but i didnt want to click the ok on the title block promted entry
so i added the  silent code before the operation, worked for me
m_InvApp.SilentOperation = True
Dim NewIdw As DrawingDocument = m_InvApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, m_InvApp.FileOptions.TemplatesPath() + "Standard.idw", True)
BP
