Open Drawing of a Part in an Assembly
j_weber
Mentor Mentor
j_weber
Hi everybody,
i have an idea and perheps someone can tell me if this is possible or not.
I have an assembly open.
In the asssembly are part components and sometimes subassemblys with part components
My Idea is now to start an iLogic rule, or vba macro.
then pick a part
after that a drawing opens.
I such for a example and found a little bit where I can pick a part.
but I can't find something where I open a drawing from the part.
found this as example
Dim comps As ObjectCollection
Dim comp As Object
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
	comp = ThisApplication.CommandManager.Pick(
		SelectionFilterEnum.kAssemblyOccurrenceFilter,
		"Select a component")
	' If nothing gets selected then we're done
	If IsNothing(comp) Then Exit While
	comps.Add(comp)
End While
' If there are selected components we can do something
For Each comp In comps
	comp.delete
Next
It works and I can pick a part, but I don't know who I can open the drawing from the part.
I think it must be at the position where comp.delete
Hope it is not to strange.
thanks for reading
Jörg
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
FINET_Laurent
Assuming the drawing name has the same name as the part name, and are both located in the same directory :
Dim oPartName As String
Dim oPart As ComponentOccurrence = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter, "Pick a part")
Dim oDrawingName As String
Dim oPartNameWithoutExtension As String
Dim oDoc As Document
 oPartName = oPart.ReferencedDocumentDescriptor.FullDocumentName
	oPartNameWithoutExtension = Split(oPartName,".ipt")(0)
			oDrawingName = oPartNameWithoutExtension & ".idw"
				oDoc = ThisApplication.Documents.Open(oDrawingName,True)
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
j_weber
Hi @FINET_Laurent
Great. It works good.
Often my drawings are not in the same folder like the part.
But when the drawing is in the same folder with the same name, it work perfectly.
thanks a lot.
Jörg Weber
fullevent
Hello Jörg,
wenn deine Zeichnung nicht im exakt selben Ordner liegt, kann man einen anderen Bereich zum Durchsuchen festlegen?
z.B. den gesamten Workspace durchsuchen inkl. aller Unterordner.
Je mehr Ordner/Dateien durchsucht werden, desto länger dauert natürlich die Prozedur.
If your drawing is not in the exact same folder, can you specify a different area to browse?
E.g. search the workspace including all subfolders.
The more folders/files are scanned, the longer the procedure will take, of course.
Gruß/regards,
Aleksandar Krstic
Produkt- und Projektmanager
