Open drawing - Either DWG or IDW based on Part number
alexander.duell
alexander.duell
I have this Ilogic code, see below:
im oOccurrence As ComponentOccurrence
Dim Prop As String
Try
  oOccurrence = ThisDoc.Document.SelectSet.Item(1)
Catch
  Ritnummer = iProperties.Value("Project", "Part Number")
				ThisDoc.Launch(Ritnummer + ".idw")
  Return
End Try
If TypeOf oOccurrence Is ComponentOccurrenceProxy Then
    Prop = iProperties.Value(oOccurrence.NativeObject.Name, "Project", "Part Number")
Else
    Prop = iProperties.Value(oOccurrence.Name, "Project", "Part Number")
'Display Property in Msg Box
Ritnummer = iProperties.Value(oOccurrence.Name, "Project", "Part Number")
Try 'Try open a drawing with the same name as this model
			Catch 'If no model is found show a message box
				MessageBox.Show("Hittar ej någon ritning för markerad del" & vbCrLf & "Ritningsnummer: " & iProperties.Value(oOccurrence.Name, "Project", "Description")& vbCrLf &"Modellnamn: "  & Ritnummer , "FEL")
		End Try
 For now, it only works for IDW's.
I would like to mod it to work also for DWG's.  Basically, a loop that tries to open a dwg, if that fails, try to open aidw, if that also fails, give the messagebox that tells that there isnt a drawing.
How would that Ilogic look like? Im having a hard time figuring that loop out.
Best Regards
Alex
FINET_Laurent
Hi @alexander.duell,
You could simply add a try/catch statement in the existing catch statement as folowing :
Dim oOccurrence As ComponentOccurrence
Dim Prop As String
Try
Catch
	Return
End Try
Else
	Try
		ThisDoc.Launch(Ritnummer + ".dwg")
	Catch
		MessageBox.Show("Hittar ej någon ritning för markerad del" & vbCrLf & "Ritningsnummer: " & iProperties.Value(oOccurrence.Name, "Project", "Description") & vbCrLf & "Modellnamn: " & Ritnummer, "FEL")
	End Try
End Try
But I think it would be better to check if the file exists before trying to open it.. thus avoiding to intentionally throw an error. You can check if a file exists like so :
If IO.File.Exists(Ritnummer + ".idw") = True Then
	Return
If IO.File.Exists(Ritnummer + ".dwg") = True Then
	Return
Does this suits your needs ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
alexander.duell
Yes i think the IF loop is hte way to go.
But how would i implement that in the code?
I think the code as meant to work as if nothing is marked it tries to the the drawing of the part/ assembly that is open.
But when using part priority, it opens the drawing of the selected part.
Best Regards
Alex
FINET_Laurent
@alexander.duell,
Can you provide us the full function so we can have a better understanding of what it is supposed to do ?
Kind regards,
FINET L.
alexander.duell
Oh, i thought i did.
Well, se below:
Dim Prop As String
Try
Catch
  Return
End Try
Else
		End Try
 Best Regards
Alex
FINET_Laurent
Hi @alexander.duell
No you didn't. I'm asking because I see you are using a return statement in your code, but not returning any value.. Anyway, here is the full function with the code implemented :
Private Function openDoc() As Boolean
	Dim Prop As String
	Try
	Catch
		Return True
	End Try
	Else
		Return True
		Return True
	Return False
End Function
Here is also some lecutre that might help you understand :
Return Statement - Visual Basic | Microsoft Learn
Procedures - Visual Basic | Microsoft Learn
