Open and save
Open and save
Open and save
I set open and save to save as: dxf.  I still get message do I want to save as dwg when I try to exit the file.  Was curious what open and save is for?  Anything to prevent me from having a dxf and a dwg in same folder.
Thanks for any tips.
k14348
question was not clear
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try to use below VBA code to suppress Inventor default prompts.
'Before saving to .dxf or dwg
ThisApplication.SilentOperation = True
'After saving to .dxf or dwg
ThisApplication.SilentOperation = False
Can you please provide your code for further Investigation? please make sure that source code is non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thanks so much for the support!!
