Open and Save Method Enigma
Here's something I can't explain to me while saving a Drawing document.
I've a Bpart.idw copied from Apart.idw document. The Apart.idw and Bpart.idw reference Apart.ipt
Here's the code I 've used first with the .Open Method and Openvisible parameter set to "True". This works fine. Bpart.idw reference Bpart.ipt.
Then I change the Openvisible to "False". In this case Debug.Print function calls show the good result for the .ReplaceReference method. But when opening the Bpart.idw, Apart.ipt is still referenced.
Sub ReplaceReferenceIdw()
Dim oDrwName As String
oDrwName = "c:\Temp\Bpart.idw"
Dim oNewName As String
oNewName = "c:\Temp\Bpart.ipt"
'Open the Drawing document
Dim oDrwDoc As DrawingDocument
Set oDrwDoc = ThisApplication.Documents.Open(oDrwName, False)
' Search for the first referenced document (assuming it is unique)
Dim oDocDescriptor As DocumentDescriptor
Set oDocDescriptor = oDrwDoc.ReferencedDocumentDescriptors.Item(1)
Dim oFileDescriptor As FileDescriptor
Set oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
Debug.Print oFileDescriptor.FullFileName 'Show referenced document
' Replace referenced document, Update it, Save it and Close it
Call oFileDescriptor.ReplaceReference(oNewName)
Call oDrwDoc.Update
Call oDrwDoc.Save
Debug.Print oFileDescriptor.FullFileName 'Show referenced document again
Call oDrwDoc.Close
End Sub
Obviously, there's something I can't understand. Is anyone could explain that to my tired brain.
C.Saint
The problem here is that drawings depend heavily on a view being present in
order to update. In this case, although ReplaceReference succeeds, the
drawing doesn't recognize this as being a 'dirtying' change and hence the
Save turns out to be a no-op. To fix this, simply add the following line of
code to explicitly dirty the document after you've changed the reference and
before saving the document.
oDrwDoc.Dirty = True
Sanjay-
wrote in message news:5475776@discussion.autodesk.com...
Call oDrwDoc.Update
Call oDrwDoc.Save
Call oDrwDoc.Close
End Sub
C.Saint
Thank you Sanjay !
It's Ok now.
C.Saint
