open a part from a drawing to see update
Using the 'Run Other' rule I can run a rule to switch holes on & off in a part. The rule is in the part & the run other rule in the drawing. The drawing will only update once the part is open. I would like to see the part open when the rule is ran from the drawing, how can this be done?
Thanks MES
jdkriek
You are looking for Launch() 😉
Dim File As String
File = "Circ Flat Membrane.ipt"
iLogicVb.RunRule(File, "NoHoles")
ThisDoc.Launch(File)
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Perfect
Many Thanks
jdkriek
You're welcome 😉
Jonathan D. Kriek
