Open a document using api does not trigger onOpen event.
jmacapagal2CD9H
jmacapagal2CD9H
Good day,
When I tried to a document using .net api it does not trigger or fire onOpen event. It will only file the event when opening the document from the inventor application. Does anyone know if this the expected behavior?
Thank you for answering.
earl_cody
Hi @jmacapagal2CD9H - The events in the ApplicationEvents object should work with open document calls from the api.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-ApplicationEvents
Here is a screenshot of a default SDK plugin template with a couple of events set:
jmacapagal2CD9H
Thank you for your response, I've done the same thing and call m_nventorApplication.Documents.Open(FullFileName) but still not working on my side. I haven't try using the default template maybe worth to try. Thank you again.
