Open 3rd Party (PDF)
inventor4578
inventor4578
Sometime i put PDF of datasheet into part on 3rd Party, i would like to know if it possible to open it by iLogic ?
Thank you very much,
Regards.
WCrihfield
Sure.  As long as your computer has a default program set-up to open PDF files.  Here is the simplest way to do it.
ThisDoc.Launch("FT.pdf")
Since that document is embedded in your Inventor document, it's kind of like it's loaded into memory, so you can open it by just the file name shown in your browser, without knowing the whole path.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
inventor4578
It's working !
It is possible to list in a listbox the attached files ?
