OnSelect event help
OnSelect event help
OnSelect event help
Here is the code i have  so far. I want to select an object and see the type of the selected object and then remove the handler. Any help with this code???
Class TestShared
Shared WithEvents oUIEvents As UserInputEvents
Sub main
oUIEvents = ThisApplication.CommandManager.UserInputEvents
AddHandler oUIEvents.OnSelect, AddressOf oUIEvents_OnSelect
End Sub
Sub oUIEvents_OnSelect(JustSelectedEntities As ObjectsEnumerator, MoreSelectedEntities As ObjectCollection, SelectionDevice As SelectionDeviceEnum, ModelPosition As Point, ViewPosition As Point2d, View As Iventor.View )
	MessageBox.Show(JustSelectedEntities.Type)
	'RemoveHandler oUIEvents.OnSelect, AddressOf oUIEvents_OnSelect
	oUIEvents = Nothing
End Sub
End Class
frederic.vandenplas
Hi, This one triggers the event and removes the handler after the first click.
I hope you add your needs to this example!
if found my inspirarion here...
Imports Inventor
Public Class SelectEventHanlder1
Private _interactionEvents As Inventor.InteractionEvents
Private _selectEvents As Inventor.SelectEvents
 Sub main
_interactionEvents = ThisApplication.CommandManager.CreateInteractionEvents()
_selectEvents = _interactionEvents.SelectEvents
AddHandler _selectEvents.OnSelect, AddressOf SelectEvents_OnSelect
_interactionEvents.Start()
End Sub
 Public Sub SelectEvents_OnSelect(ByVal JustSelectedEntities As Inventor.ObjectsEnumerator, ByVal SelectionDevice As Inventor.SelectionDeviceEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View)
  MessageBox.Show(JustSelectedEntities.Item(1).ToString)
RemoveHandler _selectEvents.OnSelect, AddressOf SelectEvents_OnSelect
	_interactionEvents = Nothing
 End Sub
End Class
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
frederic.vandenplas thanc for the help. I use ilogic so this is my final code for selecting
Shared WithEvents _interactionEvents As InteractionEvents
Shared WithEvents _selectEvents As SelectEvents
 Sub Main
End Sub
 _interactionEvents.Stop()
End Sub
End Class
