OnSave Document Event
If you are coding in the OnSaveDocumentEvent
in here you open a part and do an update on the part
Will that cause the OnSaveDocument to Fire Again???
You should make sure you are doing this in the kBefore (and not kAfter). If
so, the event shouldn't fire twice (I haven't tried this particular
experiment myself). Of course, if you modified and saved the other part, the
event will fire (kBefore and kAfter) for the other part.
Sanjay-
wrote in message news:5119798@discussion.autodesk.com...
