OnNewDocument Application Event
Vb.net 2008
Inventor 2009 and 2010
In an assembly, I need to know when the OnNewDocument event fires if it was
fired because a user was mirroring a part in the assembly.
Is there a way to do this?
Try checking the Application.CommandManager.ActiveCommand property during
the event. It should return a string that corresponds to the mirror command.
Sanjay-
That solves my problem - thank you.
"Sanjay Ramaswamy (Autodesk)" wrote in
message news:6158116@discussion.autodesk.com...
> command.
> Sanjay-
