One simple question. How can I make a folder visible or not with iLogic?
Hello!
So I have some parts from an assembly grouped into a folder. How can I make that folder and the parts from that folder visible or not with iLogic?
Thank you!
Sergio.D.Suárez
I have tried this ilogic code and it works. Be sure to place the paths of your files and folders well.
If you see an error, check that you have permission to modify these files and not just read.
'File Hidden
IO.File.SetAttributes("C:\Users\Sergio\Desktop\BloquePrint3D.ipt", IO.FileAttributes.Hidden)
'Folder Hidden
IO.File.SetAttributes("C:\Users\Sergio\Desktop\DWG", IO.FileAttributes.Hidden)
 I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
mcgyvr
@Anonymous wrote:
One simple question....
Assumptions of simplicity strike again..... or maybe I assumed incorrectly here too..
@Sergio.D.Suárez
I think they meant a model browser folder and the files inside it.. Not Windows files/folders..
@Anonymous  You really didn't explain how you want this code to determine which folder it should select but there should be some examples here that get you going..
https://forums.autodesk.com/t5/inventor-customization/ilogic-control-browser-folders/td-p/4644503
I found after all the solution:
oPane = ThisApplication.ActiveDocument.BrowserPanes("Model")
Select Case folder_visibility
    Case "No"
        oFolder = oPane.TopNode.BrowserFolders.Item("New Folder")
        oFolderNodes = oFolder.BrowserNode.BrowserNodes
        For Each oNode As BrowserNode In oFolderNodes
        oComp = oNode.NativeObject
        oComp.Visible = 0
        oComp.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
        Next
    Case "Yes"
        oComp.Visible = 1
        Next
End Select
mcgyvr
    Case "No"
        oComp.Visible = 0
        Next
    Case "Yes"
        oComp.Visible = 1
        Next
End Select
You didn't mention anything about setting the parts to reference bom structure in your original post?
Sergio.D.Suárez
You're right, I'm sorry I misunderstood the text! Regards 😁
Mechanical Designer
