OLE files in drawing(idw)
I'm limited to one table definition for parts lists, no add option to
ReferencedOLEFileDescriptors, so is there another way of adding a table of
information to a drawing sheet?
I would like to add all the variation values for an IPart to a drawing.
Scott
If you have data in your hand, you can create table with data using Inventor API thru normal lines with some constrainst.
I would like to build a table from the IPart table
defined in the drawing view.
Would you be suggesting I sketch the table, add
heading and labels all via the API?
Scott
