offset by distance in drawing sketch
Vincent_Campas
Vincent_Campas
This is always giving me a parameter incorrect error.
I tried adding different things to the collection (sketchlines, sketchentities, ...SketchLines.item(1), ....)
But always the parameter incorrect.
Sub main()
	Dim oDrawingDocument As DrawingDocument = ThisDoc.Document
	Dim oSheet As Sheet = oDrawingDocument.ActiveSheet
	Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Pick view where the sections shoud be made")
	If oView Is Nothing Then Exit Sub
	Dim ClArray As New ArrayList
	KeepAdding:
	Dim oSelectCenterline As Centerline = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCenterlineFilter, "Pick the centerlines where a section shoud be made")
	If Not oSelectCenterline Is Nothing Then
		ClArray.Add(oSelectCenterline)
		GoTo KeepAdding
	For Each oCenterLine As Centerline In ClArray
		Dim oSketch As DrawingSketch
		Dim oObjCol As ObjectCollection
		oObjCol = ThisApplication.TransientObjects.CreateObjectCollection
		oSketch = oView.Sketches.Add
		Dim oSketchEntity As SketchEntity = oSketch.AddByProjectingEntity(oCenterLine)
		oObjCol.Add(oSketchEntity)
		oSketch.OffsetSketchEntitiesUsingDistance(oObjCol, 150, True, False, False)
		'Create section on this sketch
		'oSheet.DrawingViews.AddSectionView(oView, oSketch, oPoint, DrawingViewStyleEnum.kFromBaseDrawingViewStyle, 1 / 100, True, oLabelName, , False, 300)
	Next
End Sub
Ralf_Krieg
Hello
Try to enter sketch edit mode before projecting and offset. By the way oPoint is not defined, the next point of failure. 😉
Set oPoint to 0,0 just for test it worked.
Sub main()
	KeepAdding:
		GoTo KeepAdding
		oSketch.Edit
		oSketch.OffsetSketchEntitiesUsingDistance(oObjCol, 1.5, True, False, False)
		oSketch.ExitEdit
		Dim oPoint As Inventor.Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
	Next
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
Vincent_Campas
Thanks!
Do you need to edit every sketch before you do something with it?
Because the project geometry worked withouth editing, but the offset didn't.
Yeah oPoint and olabelName weren't declared yet, Wasn't ready for that part yet.
Ralf_Krieg
Hello
Some operations can be done without entering edit mode. I never found a list which. I always try without and if it fails second try with edit mode. ^^
R. Krieg
RKW Solutions
