Occurrences in the assembly
pavol_krasnansky
pavol_krasnansky
Hi. I want to get a FullFileName from a suppressed occurrences and non-suppressed occurrences in an Assembly. I tried iLogic rule below. The rule works correctly for a part or an assembly.. Issues is when the occurrence is for example a weld or a virtual component or other item that can be suppressed and does not have the FullFileName. How can I check if the item is the part or the assembly?
Sub Main()
	Dim oDoc As Document = ThisDoc.Document
	If oDoc.DocumentType = kAssemblyDocumentObject Then
		Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
		Dim oOccs As ComponentOccurrences = oAsmDoc.ComponentDefinition.Occurrences
		Dim oOcc As ComponentOccurrence
		Dim List_Of_Components As New List(Of String)
		For Each oOcc In oOccs
			If oOcc.Suppressed = True Then
				List_Of_Components.Add(oOcc.ReferencedFileDescriptor.FullFileName & "- Suppressed - True")
			ElseIf oOcc.Suppressed = False Then
				List_Of_Components.Add(oOcc.ReferencedFileDescriptor.FullFileName & "- Suppressed - False")
		Next
		a = InputListBox("List Of Components:", List_Of_Components)
End Sub
A.Acheson
You can check the type of component definition
If Typeof oOcc.Definition PartComponentDefinition Then
   'Do Something
ElseIf Typeof oOcc.Definition Is AssemblyComponentDefinition Then
    'Do Something
Or the same but different method of writing type
If oOcc.Definition.Type = ObjectTypeEnum.kPartComponentDefinitionObject Then
   'Do Something
ElseIf oOcc.Definition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
    'Do Something
Or check the definitiondocument type
If Typeof oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
   'Do Something
ElseIf Typeof oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
    'Do Something
Regards
Alan
pavol_krasnansky
Thank you, but it does not work.
Solutions 1 and 2 only work for non-suppressed components.
Solution 3 does not work for a weld (for example) because a weld is also a kAssemblyDocumentObject. I look for an universal solutions for every cases.
Sub Main()
		MsgBox(oOcc.Name)
		MsgBox(oOcc.DefinitionDocumentType.ToString())
			' If Typeof oOcc.Definition Is PartComponentDefinition Or
			' Typeof oOcc.Definition Is AssemblyComponentDefinition Then
			' If oOcc.Definition.Type = ObjectTypeEnum.kPartComponentDefinitionObject Or
			' oOcc.Definition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
			If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Or
		Next
End Sub
A.Acheson
You probably have no option but to check suppresed status then unsuppress occurrence check your filename and then suppress again.
Regards
Alan
pavol_krasnansky
The code below works:
Sub Main()
			If oOcc.ReferencedFileDescriptor IsNot Nothing Then
		Next
End Sub
