Occurrences from Document
Hey
Hoping someone can help me out here, i cant seem to get this right.... Im using DocumentsEnumerator to get all assembly references. These consist of parts & sub assemblies. There are some instances where we get an assembly with 1 single part inside so in those instances, I need to promote that part out of the found assembly into the top level assembly and then delete the found assembly. ALL of the sub assemblies are only 1 level down so this should be straight forward but im not getting it right tonight... The DocumentsEnumerator has an assembly DocumentType condition as shown below
Dim CurrDoc As AssemblyDocument = _invApp.ActiveDocument
Dim oRefDocs As DocumentsEnumerator = CurrDoc.AllReferencedDocuments
' Iterate through the list of documents.
For Each oRefDoc As Inventor.Document In oRefDocs
Select Case oRefDoc.DocumentType
Case DocumentTypeEnum.kAssemblyDocumentObject
'Call Promote HERE
Dim CurrAssy As AssemblyDocument = oRefDoc 'see below
Promote(CurrAssy)
End Select
NextThe big problem i am finding is oRefDoc. I am trying to assign it as something but i cannot seem to access Document, ComponentDefinition or ComponentOccurrence. I was hoping for oRefDoc.Document.ComponentDefinition
Im using this code from api to promote
Public Sub Promote(ByVal FoundAssembly As AssemblyDocument)
'need to use FoundAssy in the sub
' Get the active assembly document
Dim oDoc As AssemblyDocument = _invApp.ActiveDocument
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
' Get the top level occurrence of an assembly
Dim oSubAssyOcc As ComponentOccurrence = oDef.Occurrences.Item(1)
' Get the 2nd level occurrence under the assembly occurrence
Dim oSubOcc As ComponentOccurrenceProxy = oDef.Occurrences.Item(1).SubOccurrences.Item(1)
Set oSubOcc = oSubAssyOcc.SubOccurrences.Item(1)
Dim oPane As BrowserPane = oDoc.BrowserPanes.Item("Model")
' Get the browser nodes corresponding to the two occurrences
Dim oTargetNode As BrowserNode
Set oTargetNode = oPane.GetBrowserNodeFromObject(oSubAssyOcc)
Dim oSourceNode As BrowserNode
Set oSourceNode = oPane.GetBrowserNodeFromObject(oSubOcc)
' Reorder the nodes to promote the sub-occurrence to the top level
Call oPane.Reorder(oTargetNode, True, oSourceNode)
oSubAssyOcc.Delete
End Sub
i know that oSubASssyOcc needs to be the the found Assembly oRefDoc in the Enumerator but as an occurrence. Seeing as its been found in the enumerator, not a top level loop, its not an occurrence per se because its been found as an object in the enumerator instead. So, i cant get this to work properly. It looks like the Browsernode is expecting an occurrence hence why this isnt working. What am i not seeing?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
