Occurrences.Add does not work?
Hi all,
i am getting this issue when running this code on other people inventor but it works on mine
i was wondering if it is the location of the files with in the C:/ drive so i put the files on a shared drive and it is still the same.
it crashes out because it does not place any parts.
Background i am passing in Builder_Options As ArrayList and  SystemArea As String
can anyone help me with this i cant get my head round why it works on my pc but not others ?
Kind Regards
CODE_____________________
'start new inventor assembly
Dim ThisApplication As Inventor.Application
ThisApplication = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
ThisApplication.SilentOperation = True
Dim StartDoc As AssemblyDocument
StartDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject)
'StartDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
'oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
oAsmCompDef = StartDoc.ComponentDefinition
'Create a new matrix object. It will be initialized to an identity matrix.
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
' add all options to assembly
Dim SectionSelection As String
For Each SectionSelection In Builder_Options
oAsmCompDef.Occurrences.Add("C:\VaultWorkspace\Vault\" & SystemArea & "\" & SectionSelection & ".iam", oMatrix)
Next
JelteDeJong
hi, i didn't see any direct problems with your code. but i alterd the loop a bit maby it will help you to figure out the problem. i did the following:
  • Combining the strings to a path can be better left to a function that is made for that. When you use IO.Path.Combine() you dont need to wory any more about adding slashes.
  • i added a check to see if the create full file name realy exists.
  • i added a try/catch block. If 1 file fails to add it will show a messagebox but will continue.
    Dim fullFilename As String = IO.Path.Combine("C:\VaultWorkspace\Vault\", SystemArea, SectionSelection & ".iam")
    If (IO.File.Exists(fullFilename)) Then
        Try
            oAsmCompDef.Occurrences.Add(fullFilename, oMatrix)
        Catch ex As Exception
            MsgBox("Error while placing part: " & fullFilename & " Inventor Error message: " & ex.Message)
        End Try
    Else
        MsgBox("Error while placing part. Following file does not Exists: " & fullFilename)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
thank you for having a look at my code I have changed it with your bits but it still does not work I now get an error come up.
it says it can not find the file ( but I have checked the file is 100% there and it runs fine on my pc)
ERROR:
the parameter is incorrect. (Exception from HTRDULT: 0x80070057 (E_INVALIDARG)
the line if fails on is
I have had a little google with no luck.
any advice or help would be fantastic
Kind Regards
