Object Visibility of sketches API
lmc.engineering
lmc.engineering
Hi all,
I am a bit of a noob when it comes to fully understanding programming, and this is a prime example of a hole in my knowledge:
All I want to do is use an iLogic rule to turn off sketch visibility using the Object visibility. I don't need to cycle through all parts to get the sketches and turn off.. I can actually do that already, I just want the override option for automated screenshots.
I have tried the following
Inventor.ObjectVisibility.Sketches = False
AssemblyDocument.ObjectVisibility.Sketches = False (I believe this method to be read only)
I can see in Visual studio object browser that this is possible, but my stupidity is stopping me from getting the right line of code..
I know this should be simple for someone who can actually program, I just cant get the **** thing to work.
Any help is greatly appreciated
frederic.vandenplas
This is pretty easy to accomplish
(vba code)
Sub ChangeViz()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
oDoc.ObjectVisibility.Sketches = False
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
