Object Variable or With block Variable Not Set - Help
Message 1 of 9
I'm using the following code from the Inventor help example to set my project. But I get this error, "Object Variable or With block Variable Not Set." It may be that I'm using .NET, not sure?
Thx,
Jon
Public Sub SetProject()
' Check to make sure a document isn't open.
If ThisApplication.Count > 0 Then
MsgBox("All documents must be closed before changing the project.")
Exit Sub
' Set a reference to the FileLocations object.
Dim oFileLocations As FileLocations
oFileLocations = CType(ThisApplication.FileLocations, FileLocations)
' Show the current workspace.
Debug.Print("Workspace: " & oFileLocations.Workspace)
' Set the project file to use.
' This assumes that "C:\Temp\MyProject.ipt" exists.
oFileLocations.FileLocationsFile = "F:\Global-Edit.ipj"
' Show the workspace after making the project change.
End Sub
Replies (8)
Message 2 of 9
There were a couple of syntax issues. You need a
set for the following line:
Set oFileLocations =
Try the following macro.
Sanjay-
open.
If ThisApplication.Documents.Count > 0
Then
MsgBox ("All documents must be closed before
Exit Sub
object.
Debug.Print ("Workspace: " &
exists.
change.
End Sub
Message 3 of 9
Thanks Sanjay, I got it to work.
Message 4 of 9
Sanjay,
Here's a similar problem with the following code that is straight forward in VBA but expects something else with .net.
Public Sub ActiveDocumentSample()
' Declare a variable to handle a reference to a document.
Dim invDoc As Document
' Set a reference to the active document.
Set invDoc = ThisApplication.ActiveDocument
MsgBox "Got document: " & invDoc.DisplayName
End Sub
The "ThisApplication.ActiveDocument" portion gives me the following error:
Implicit conversion from "Object" to "Inventor Document"
I'm not sure how to cast this object.
Thx,
Jon
Message 5 of 9
Hi Jon,
ThisApplication is a property that returns
Inventor's Application object and is ONLY AVAILABLE FROM WITHIN
INVENTOR'S VBA ENVIRONMENT.  If you're using Inventor's API from anywhere
else besides Inventor's VBA you have to get access to the Application object in
a different way.  If you're writing an Add-In you can get it during the
Activate method through the Application property of the ApplicationAddInSite
object that's passed as the first argument of the Active method.  If you're
writing an EXE program then you can use the VB GetObject function.
Brian Ekins
Autodesk Inventor API
href="http://blogs.autodesk.com/modthemachine">http://blogs.autodesk.com/modthemachine
Message 6 of 9
Hi Brian,
This code is probably a bad example concerning the context of what I'm trying to do. Let me explain what I'm try to do.
Before I set a project in Apprentice I want to verify there are no Inventor documents open, which means Inventor could be active. I understand Inventor's Application object and how it is available from within VBA only. However, is there ever a time when the Application object can be accessed in different ways Within the same software application? For example, before I set my project I may want to check to see if a document is active before I run my routine. Though my application is Apprentice, wouldn't I have to use Inventor's Application object to check if a document is open in Inventor? Because obviously Apprentice doesn't have activeDocument, though I have tried some things (unsuccessfully). Perhaps I should just make sure Inventor isn't running, but I can't always be sure the end user will know to shut it down and, therefore, could potentially hose an assembly drawing. Maybe I'm fussing about nothing.
Thx,
Jon
Message 7 of 9
At any rate, the ApplicationAddInSite object is what I hadn't thought of during this process.
Message 8 of 9
Brian,
I solved it with the following. Maybe you have a better idea, but it works. I wouldn't have known without your input.
Dim oApp As Inventor.Application
Try
oApp = CType(GetObject(, "Inventor.Application"), Inventor.Application)
oApp.Documents.CloseAll()
Catch ex As Exception
Exit Try
End Try
Thx,
Jon
Message 9 of 9
GetObject is what I would have used to.
Brian Ekins
Brian,
wouldn't have known without your input. Dim oApp As Inventor.Application Try
oApp.Documents.CloseAll() Catch ex As Exception Exit Try End Try Thx,
Jon
