Numbers on Parts
Numbers on Parts
Numbers on Parts
I have a part that will remain the same except for a number that is cut out.  I need to sequence numbers (1,2,3...) extending into the hundreds. Is there a way to set this up where each part does not need to be created manually?
rjay75
Attached is a sample file that I think does what you're looking for. It uses a text as a sketch profile for extruding. In it is an iLogic rule that will ask for a start and end number. Increment and update the part and save the files out.
