Null Reference Exception
jpchaisson
Message 1 of 8
jpchaisson
its been a few years since ive gotten my hands dirty with writing code for Inventor and im getting an error when i test a few lines of code and i cant figure out why. if i open old projects and run the code everything works. so i have a Drawing open in Inventor and i have two custom iProperties on the drawing that is blank at the moment and i have a small vb.net UI with a button, when i click the button im trying to populate the custom iProperties with values hard coded just as a test to get the code correct. Line 4 throws me a Null Reference Exception. can anyone explain what im missing?
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim oStation As String = "Test"
Dim oStationID As String = "Test ID"
Dim oApp As Inventor.Application = GetObject(, "Inventor.Application")
Dim oDoc As DrawingDocument = oApp.ActiveDocument     '<-------Problem Line-----
Dim oCustomiProp As PropertySet
oCustomiProp = oDoc.PropertySets.Item("Inventor User Defined Properties")
oCustomiProp.Item("Station").Value = oStation
End Sub
Replies (7)
Message 2 of 8
dalton98
Dim oObj As String = "Inventor.Application"
Dim oApp As Inventor.Application = GetObject(, oObj)
oDoc = oApp.ActiveDocument
Message 3 of 8
jpchaisson
Still getting a Null Reference.... i am really confused this is such a simple line of code and ive never gotten this before.
Message 4 of 8
dalton98
I'm not familiary with VBA, but I believe you need to write 'Set' in front of new objects. This is an example from the api helper. It can be found by clicking the drop down for the (?) in the top right > Help > Programming/API help.
Public Sub CreateCustomTable()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
Message 5 of 8
jpchaisson
This is VB.NET not VBA
Ive never had this problem before. its driving me crazy. everything looks correct
Message 6 of 8
dalton98
Message 7 of 8
WCrihfield
Hi @jpchaisson.  It is possible to have the Inventor application open, without actually having any documents open.  Could that possibly be the case here?  Then there is the situation where you might have multiple instances of Inventor open...one with 1 or more documents open, and the other with no documents open, and maybe your code is grabbing the instance without any open documents.  Just throwing some stuff out there.
Wesley Crihfield
(Not an Autodesk Employee)
Message 8 of 8
JelteDeJong
try replacing the line:
with the following:
Dim oApp As Inventor.Application =  System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
Jelte de Jong
Blog: hjalte.nl - github.com
