Not run script if a drawing is an assembly drawing
Gwennberg
Gwennberg
Hi
How could I check if my drawing reference to an assembly? I have a script that makes pdf and stp-file but I do not want to make a stp-file in an assembly case.
BR/Goran
WCrihfield
Hi @Gwennberg.  The quickest and simplest way to check what type of model document is being represented by a drawing (assuming there is only one model), is to use something like this iLogic code:
oDrawingDoc = ThisDrawing.Document
oModel = ThisDrawing.ModelDocument
If oModel.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	Exit Sub
'the rest of your code here
Those lines will only work in iLogic, not in VBA.  There are also other ways to obtain referenced model documents from a drawing document, then check their type too, if needed.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Gwennberg
Thank you Crihfield
It worked out well.
BR/Goran
