I have been making an ilogic that automatically adds custom bars into a frame. i have managed to get each constraint to work on their own however when I un comment the second or third constraint then i get an error saying the Parameter is incorrect even though i know it isn't.
Has anyone else had this problem before?
it only seems to happen to certain parts as earlier in the same code i have a version with a contents just the standard bar and i can constrain that as much as i want (without over constraining obviously).
StandardOccurrence = oAsmDoc2.ComponentDefinition.Occurrences.Add(StandardBarFile, ThisApplication.TransientGeometry.CreateMatrix()) StandardBar = StandardOccurrence.SurfaceBodies.Item(1) FaceCount_StandardBar = StandardBar.Faces.Count Dim StandardBarTopFace As Face = StandardBar.Faces(FaceCount_StandardBar) Dim StandardBarSideFace1 As Face = StandardBar.Faces(7) Dim StandardBarSideFace2 As Face = StandardBar.Faces(15) Dim StandardBarFrontFace As Face = StandardBar.Faces(13) Dim oPartDoc As PartDocument = SR2BarOccurrence.Definition.Document Dim Number As Double = 1 Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap1") = worksheet.Range("D9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap2") = worksheet.Range("E9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap3") = worksheet.Range("F9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap4") = worksheet.Range("G9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap5") = worksheet.Range("H9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap6") = worksheet.Range("I9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap7") = worksheet.Range("J9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap8") = worksheet.Range("K9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap9") = worksheet.Range("L9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Gap10") = worksheet.Range("M9").Value Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "B_L") = Height_Gap Parameter("5634 - SR2 Bar Infill For Generator:" & Number, "Top_Gap") = worksheet.Range("O9").Value SR2Bar = SR2BarOccurrence.SurfaceBodies.Item(1) FaceCount_SR2Bar = SR2Bar.Faces.Count Dim SR2BarTopFace As Face = SR2Bar.Faces(FaceCount_SR2Bar) Dim SR2BarBottomFace As Face = SR2Bar.Faces(FaceCount_SR2Bar - 1) Dim SR2BarFrontFace As Face = SR2Bar.Faces(FaceCount_SR2Bar - 13) Dim SR2BarSideFace1 As Face = SR2Bar.Faces(FaceCount_SR2Bar - 11) Dim SR2BarSideFace2 As Face = SR2Bar.Faces(FaceCount_SR2Bar - 11) Dim oConstraint1 As MateConstraint = oAsmDoc2.ComponentDefinition.Constraints.AddMateConstraint(SR2BarSideFace2, SideFace1, 10) Dim oConstraint2 As MateConstraint = oAsmDoc2.ComponentDefinition.Constraints.AddMateConstraint(SR2BarTopFace, TopFace, 0) Dim oConstraint3 As FlushConstraint = oAsmDoc2.ComponentDefinition.Constraints.AddFlushConstraint(SR2BarFrontFace, OuterFace, 0)
