New Sheet, Prompted entry window pops up, want to either fill in automaticaly, autopress ok button or esc key
G.Binl
Message 1 of 9
G.Binl
I am still fairly new to Ilogic still.
I have a simple rule that creates a new Drawing sheet.
1. It starts a new sheet
2. Adds Title Block
3. Prompts for Entries. ((a pop up window is displayed))
( I believe this is a sketch that lives with in the Title Block but I may be wrong on this.)
at stage 3.
I want to either auto Fill the Entries,  Esc. out of the active window,  Auto click the ok button.
Here is the code I am using.
I have been trying many different ways based on things  i have found on the web and come to the belief that i have
no understanding of ilogic. and its structured mysteries.
The reason i want this is its part of a bigger puzzle I'm working that loops creating sheets until its done.
Currently I hold the Esc. key down until its complete. I would like to clean that up.
Many Thanks for viewing This post.
Replies (8)
Message 2 of 9
blandb
You didnt have any code attached?
Autodesk Certified Professional
Message 3 of 9
G.Binl
oops sorry about that got all caught up in the message.
Sub Main
Dim oSheet As Sheet
'oSheet = oDrawDoc.Sheets(1)
'oSheet.Activate
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
' Get New Sheet of IWD
Dim oControlDef As ControlDefinition
MsgBox(1)
oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingNewSheetCtxCmd")
Try
MsgBox(2)
oControlDef.Execute2(True)
MsgBox(3)
Catch
End Try
End Sub
Message 4 of 9
A.Acheson
Welcome to the drawing automation world: You will need to change the method you add the sheet. Your skipping populating the prompted entry with the straight copy, I personally don't use prompted entry for this reason.
Here is a post message 14 adds the sheet. You have prompted entry so you will  need to supply information even if blank. Unfortunately there may be no easy way than constructing all the components that make up a drawing sheet.
Api Help Information
Add sheet
Sheetaddtitleblock
Here is a vba sample to add titleblockdefintion, if you look down the bottom you will see prompt strings and how to handle them.
Regards
Alan
Message 5 of 9
theo.bot
@G.Binl
You can combine the methode that @A.Acheson mentioned with a standard ilogic snippet for adding/changing a titleblock with prompted entries. this is a simple one line code, where you can enter all entires as stings. here's a small sample
Sub main
	Dim oDoc As DrawingDocument
	oDoc = ThisDoc.Document
	'add a blank new sheet, use DrawingSheetSizeEnum for the right size
	Dim oSheet As Sheet
	oSheet = oDoc.Sheets.Add(DrawingSheetSizeEnum.kA3DrawingSheetSize)
	'Add title block, enter the promptedentries equal to the number in your title block
	ActiveSheet.SetTitleBlock("Other Title Block", "promptedEntry1", "promptedEntry2")
	'Add custom border
	'ActiveSheet.Border = "My Border"
	'Or add default border
	oSheet.AddDefaultBorder(0,,0,,,,False,1,1,1,1)
End Sub
Message 6 of 9
G.Binl
@A.Acheson
Thanks for the info. i will try this in my code.
Is there no way to mimic pressing the Esc Key?
what is the the window called that pops up for the prompted entries?
V/r,
-g
Message 7 of 9
G.Binl
@theo.bot
Thanks for the information as i said to @A.Acheson i will give it a try.
V/r,
-g
Message 8 of 9
G.Binl
With some modification I got this to work for my use. Thanks for the help.
Message 9 of 9
G.Binl
Thanks for the information it help a lot. i ended up using Theo.bot solution with modification knowledge you pointed out.
