New Layer creation
New Layer creation
RoyWickrama_RWEI
Advisor Advisor
New Layer creation
RoyWickrama_RWEI
I found the following code from the forum: Thanks.
However, it runs one time. All fine.
But repeated use of the same gives an error message!
SyntaxEditor Code Snippet
Sub Main()            'LayerAddTest()
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
'    Dim oLayers As LayersEnumerator'    oLayers = oDrawDoc.StylesManager.Layers
    Dim oLayer As Layer
    ' oLayer = oDrawDoc.StylesManager.Layers.Item(68)
    oLayer = oDrawDoc.StylesManager.Layers.Item("Title (ISO)")
    Dim oNewLayer As Layer
    oNewLayer = oLayer.Copy("waynes_layer_copy")
'    '    oNewLayer.Color = ThisApplication.TransientObjects.CreateColor(0, 0, 255)
End Sub
 Could someone help me?
it is probably the copy that is failing on subsequent runs. according to the API
Layer.Copy Method
Input String that specifies the name for the new style. This name must be unique with respect to all other styles of a similar type in the document. That is, if a dimension style is being copied, the name must be unique with respect to all the other dimension styles. If it is not unique the method will fail.
you are not changing the name of the new layer.
RoyWickrama_RWEI
Thanks for the reply.
I was doing with another rule for the same (see the attached). It was giving me some errors. I incorporated a "Try ... Catch" and got around the problem.
Sub Main()
    Dim oLayer As Layer
    oNewLayer_Name = "XYZ"
    Try
    oNewLayer = oLayer.Copy(oNewLayer_Name)
    Catch
    MessageBox.Show("New layer, " & oNewLayer_Name & ": Exists", "Title")
    End Try
ThisDrawing.Document.StylesManager.Layers(oNewLayer_Name).Visible = False
ThisDrawing.Document.StylesManager.Layers(oNewLayer_Name).Plot = False
End Sub
 Thanks again.
