Neep help. InputRadioButton is mocking me
Can someone take a look at the code below and tell me what I'm doing wrong? I keep getting the error message : "ClickA is masking a variable in a global bloc" or some such. It's in french ("La variable 'ClickA' masque une variable dans un bloc englobant").
I figure it means that a variable is being declared twice, but I put it in a "IF" loop, so it should not see the second one, right?
Thank you.
SyntaxEditor Code Snippet
' --- Choisis la methode' Face - Face' Face - Point' Point - Point
Dim Choix1 as Boolean
Dim Choix2 as Boolean
Dim DistPoints As Double
Dim DistPoints2 As Double
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
'--- First selection Choix1 = InputRadioBox("Choisis le type de selection : ", "Face", "Point", True, Title := "Premiere Selection d'entite" If Choix1 = True Dim ClickA As Face ClickA = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Clique sur la Face 1 : ") Else Dim ClickA As Point ClickA = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Clique sur le Point 1 : ") End If
'--- Second selection Choix2 = InputRadioBox("Choisis le type de selection : ", "Face", "Point", True, Title := "Deuxieme Selection d'entite") If Choix2 = True Dim ClickB As Face ClickB = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Clique sur la Face 2 : ") Else Dim ClickB As Point ClickB = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Clique sur le Point 2 : ") End If
'--- Measure distance DistPoints = ThisApplication.MeasureTools.GetMinimumDistance(ClickA, ClickB) DistPoints2 = DistPoints / 2.54 MessageBox.Show("Longueur = " & DistPoints2 & " pouces", "Title")
Move Dim ClickA as Face out of the IF Then block
I was hoping I wouldn't need to do that. Darn it.
Thank you
The getminimumdistance method accepts objects for entity one and two. try this
Dim ClickA as object
Dim ClickB as object
If Choix1 = True
Else
If Choix2 = True
Else
Dude! You Rock!
iLogic needs a single source of reference, like a book or complete website. Help files are nice, but hardly cover 25% of what's possible with the code.
Kudos for days!
I'm glad I could help you. There have been a lot of folks on here that have helped me.
