Need to EDIT radius of a fillet using API/iLogic
llorden4
llorden4
I can't seem to run down the features of a Fillet feature to edit the Radius value I created using a Simple Fillet.
oFillet = oCompDef.Features.FilletFeatures.AddSimple(oEdges, EdgeDist * 2.54, False, False)
I'm attempting to edit the feature vs deleting it and re-creating it.  Can anyone point me in the right direction here, the API and Help isn't being very helpful on this issue and I'm not getting any hits on my searches.
I can find my value, but it's read only.
oFillet = oCompDef.Features.Item("Edge Fillet")
MsgBox(oFillet.FeatureDimensions.Item(1).Parameter.Value)
'also works
MsgBox(oFillet.Parameters.Item(1).Value)
Autodesk Inventor Certified Professional
JelteDeJong
I could not find a neat solution. But I found something that might help. If you're creating a very simple fillet with only 1 radius. Then you will probably also have only 1 parameter.  Then you can try this:
Dim parameter = oFillet.Parameters.Item(1)
parameter.Expression = "20 mm"
Jelte de Jong
Blog: hjalte.nl - github.com
llorden4
Well that was just no where near intuitive, you can't edit the value directly but you can make a variable to a read only value and then edit the variable which can edit the read only value.
I made a small modification to use a variable in that rendition which also succeeded.
oParam = oCompDef.Features.Item("Edge Fillet").Parameters.Item(1)
oParam.Value = EdgeDist * 2.54
Thanks for the pointer!
