Need to create Sketch on a Workplane
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I am digging to get around creating a sketch on an existing workplane. It is not going through. I request provide me with help.
'  a reference to the currently active document.
' This assumes that it is a part document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
'  a reference to the component definition.
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
'  a reference to the transient geometry object.
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim doc = ThisApplication.ActiveDocument
oWP = "WP01"
oSketch = oCompDef.Sketches.Add(oWP)
Inventor 2015
Owner2229
Here you go:
' Reference the currently active document.
Dim oDoc As Document = ThisApplication.ActiveDocument
' Parts only. If oDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Exit Sub ' Reference the component definition. Dim oCD As PartComponentDefinition = oDoc.ComponentDefinition ' Reference the workplane called "WP01". Dim oWP As WorkPlane = oCD.WorkPlanes("WP01") ' Add new sketch. Dim oSketch As PlanarSketch = oCD.Sketches.Add(oWP) ' Rename the new sketch (optional). oSketch.Name = "Sketch on WP01"
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
RoyWickrama_RWEI
Thanks. It is really good enough.
However, could you revise the code so that the sketch is active for editing (as shown below):
Owner2229
Here you go.
' Start editing the sketch (optional).
oSketch.Edit()
' Exit the sketch editing (optional).
'oSketch.ExitEdit()
Mike
