Need to Assign BOM Structure data for Children in Assembly
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I have a rule where I use to edit part numbers in assembly.
I also need to assign the BOM structure data: but this part (to assign BOM structure) is not right.
I request some one help me get this rule fixed.
Sub main
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oDoc As Document
Dim oRefFile As FileDescriptor
Dim xx As Integer = 1
For Each oDoc In oAsmDoc.AllReferencedDocuments
'	Dim oDoc As Document = ThisApplication.ActiveDocument
	oDoc.DisplayName = ""
	oDT_PropSet = oDoc.PropertySets.Item("Design Tracking Properties")
	'oSI_PropSet = docFile.PropertySets.Item("Inventor Summary Information")
	'oDSI_PropSet = docFile.PropertySets.Item("Inventor Document Summary Information")
	'oUD_PropSet = docFile.PropertySets.Item("Inventor User Defined Properties")
		oPN_Doc = oDT_PropSet.Item("Part Number").Value
		Dim oPN_List As New ArrayList
		oPN_List.Add(oPN_Doc)		'oDT_PropSet.Item("Part Number").Value)
		oLFN = oDoc.DisplayName		'(False)
		'oFFN = oDoc.FullfileName(True)		'(False)
		'specify word splitting characters "space" and "dash"
		Dim Separators() As Char = {" "c, "-"c, "."c}
		Sentence = oLFN
		Words = Sentence.Split(Separators)
		i = 0
		For Each wrd In Words
			If Words(i) = "ipt" Then
			Else If Words(i) = "iam" Then
			Else
				oPN_List.Add(Words(i))
		'MessageBox.Show("Word Index #" & i & " = " & Words(i))
		i += 1
		Next
	'oPN_List.Add("Other")
	oPN_List.Add("Exit")
	L_oPN_X:
	oPN_X = InputListBox("Prompt", oPN_List, oPN_Doc, Title := "PART NUMBER", ListName := "Select - Part Number")
	If oPN_X = "" Then GoTo L_oPN_X
	If oPN_X = "Exit" Then Exit Sub
	oPN_X_Edit = InputBox("Edit/Accept", "PART NUMBER", oPN_X)
	iProperties.Value(oLFN, "Project", "Part Number") = oPN_X_Edit
	Dim oList_BOM_Structure As New ArrayList
	oReference = "kReference"
	oPhantom = "kPhantom"
	oNormal = "kNormal"
	oPurchased = "kPurchased"
	If oDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure Then oCurrBOM = oPurchased
	If oLFN.ComponentDefinition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then oCurrBOM = oReference
	If oLFN.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then oCurrBOM = oNormal
	If oLFN.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Then oCurrBOM = oPhantom
	oList_BOM_Structure.Add(oCurrBOM)
	oList_BOM_Structure.Add(oReference)
	oList_BOM_Structure.Add(oPhantom)
	oList_BOM_Structure.Add(oNormal)
	oList_BOM_Structure.Add(oPurchased)
	oBOM_Structure_Selected = InputListBox("Prompt", oList_BOM_Structure, oList_BOM_Structure(0), Title := "SELECT BOM STRUCTURE", ListName := "BOM STRUCTURE")
	If oBOM_Structure_Selected = oReference Then oDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
	If oBOM_Structure_Selected = oPhantom Then oDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
	If oBOM_Structure_Selected = oNormal Then oDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure
	If oBOM_Structure_Selected = oPurchased Then oDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
xx += 1
Next oDoc
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
End Sub
RoyWickrama_RWEI
I refined a little bit. Referred to some help from the forum.
Now, I need to access all the documents. Currently, if goes through the 1st level only.
I will add some codes to filter the checked out document only, etc.
Sub main
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
	oNormal = "kNormal"
	If oOccurrence.Definition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure Then oCurrBOM = oPurchased
	If oOccurrence.Definition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then oCurrBOM = oReference
	If oOccurrence.Definition.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then oCurrBOM = oNormal
	If oOccurrence.Definition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Then oCurrBOM = oPhantom
	oList_BOM_Structure.Add(oOccurrence.Name)
	L_oBOM_Structure_Selecte:
	oBOM_Structure_Selected = InputListBox(oOccurrence.Name, oList_BOM_Structure, oList_BOM_Structure(1), Title := "SELECT BOM STRUCTURE", ListName := "BOM STRUCTURE")
	If oBOM_Structure_Selected = oList_BOM_Structure(0) Then GoTo L_oBOM_Structure_Selecte:
	If oBOM_Structure_Selected = oReference Then oOccurrence.Definition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
	If oBOM_Structure_Selected = oPhantom Then oOccurrence.Definition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
	If oBOM_Structure_Selected = oNormal Then oOccurrence.Definition.BOMStructure = BOMStructureEnum.kNormalBOMStructure
	If oBOM_Structure_Selected = oPurchased Then oOccurrence.Definition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
Next oOccurrence
End Sub
RoyWickrama_RWEI
The rule is getting better.
Need some refinements: skip fasteners, checked-in documents, so on.
I appreciate receiving help. Thanks.
Prefixes are created in the numbering system.
fgpa: Frame generator phantom assembly
fgsk: Frame generator sketch
sk: Sketch
p: Part
A: Assembly
