need some help reprogramming my codes
berry.lejeune
berry.lejeune
Hello all,
So I've got two iLogic's which I want to combine. But I don't seem to get what I want. One of the codes is from an ipt. This code is to make a dxf in a predefined folder and this is working good. The other code is from an idw and this one makes a pdf in a predined folder as well as a pdf in the folder where the idw is.
Now I was trying to change the code from the ipt so that a dxf is being made in the folder where the ipt is. I've tried to combine both codes in several ways but I just don't get it good.
This is the code in my idw: a pdf gets made on a fixed location (g:\pdf\2022\ and another pdf is made in the folder where the idw is (ex: I:\Workspace\Ontwerpen\2022\20221169) and in this folder a new subfolder \pdf is made and there also a pdf is being made
'define the folder where you want to save the files
oFolder = "g:\pdf\2022\"
'grab the filename
oFileName = ThisDoc.FileName(False) 'without extension
'create the folder if it doesn't exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
'save as a pdf
ThisDoc.Document.SaveAs(oFolder & oFileName & -1 & ".pdf", True)
oPath = ThisDoc.Path
'get STEP target folder path
oFolder = oPath & "\" & oAsmName & " PDF"
'Check for the step folder and create it if it does not exist
ThisDoc.Document.SaveAs(oFolder & "\" & oFileName &(".pdf") , True)
This is my rule for the dxf. I have to select a face in the ipt and then run the rule and a dxf is being made in a predefined folder.
'Export face to pre-defined folder
If ThisApplication.ActiveDocument.SelectSet.Count = 0 Then
	MsgBox("Face not selected. Aborting Rule!")
	Exit Sub
oFolder = "Z:\"
oFileName = oFolder & ThisDoc.FileName & ".dxf"
Dim oCmdMgr As CommandManager
oCmdMgr = ThisApplication.CommandManager
Call oCmdMgr.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oFileName)
Call oCmdMgr.ControlDefinitions.Item("GeomToDXFCommand").Execute
 Now I would like to change my rule for the dxf so that in the folder where my parts are, a new folder is being made "\dxf\" and the dxf is stored overthere
The rules I use are the ones I found overhere and I managed to change them a bit to suit my needs but I seem not to be able to change this one now
jatindevaiya08
Hello @berry.lejeune
You just need to change oFolder string to below. It will work for you.
oFolder = ThisDoc.Path & "\dxf"
If System.IO.Directory.Exists(oFolder) = False Then
oFileName = oFolder & "\" & ThisDoc.FileName(False) & ".dxf"
Jatin Devaiya
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
