Need some help filtering Derrived components from occurences
machiel.veldkamp
machiel.veldkamp
I found a nice rule where the Textfile in the end shows which part get used in which assemblies.
But! If there is a part with a derrived component that gets counted as well.
I want to exclude all derrived components and just get all the occurences in the assembly.
Can someone help me with that?
Sub Main()
	oTextSave = "C:\TEMP\iLogicBuffer.txt"
	Dim oSelectSet As SelectSet
	oWrite = System.IO.File.CreateText(oTextSave)
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
	Dim Occ As ComponentOccurrence
	Dim oDrawingView As DrawingView
	Dim oModelDoc As Document
	Dim oStr As String = ""
	Dim oList As New List(Of Object)
	oWrite.WriteLine("FILE REFERENCE TREE RAN FROM: " & oDoc.FullFileName)
	oWrite.Close
	For Each oModelDoc In oDoc.AllReferencedDocuments
		RecurReferencing(oModelDoc, oStr, 0)
	Next
	Process.Start("Notepad.exe", oTextSave)
End Sub
Sub RecurReferencing(oDoc As Document, oStr As String, Level As Integer)
	Dim oRefDoc As Document
	'Dim oDerPartComp As DerivedPartComponent
	If Level = 0
		oStr = DocNameWExt(oDoc.FullFileName)
	Else
		'If oDoc.DocumentType() = DocumentTypeEnum.kDrawingDocumentObject Or oDoc.PropertySets.Item("Inventor Summary Information").Item("Comments").Value = ""
		'	oStr = DocNameWExt(oDoc.FullFilename) & " <- " & oStr
		'Else
		oStr = oStr & " -> " & DocNameWExt(oDoc.FullFileName)
		'End If
	If oDoc.ReferencingDocuments.Count < 1
		Try
			If oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count = 1 Then
				GoTo oEnd
			Else
				oWrite = System.IO.File.AppendText(oTextSave)
				oWrite.WriteLine(oStr)
				oWrite.Flush()
				oWrite.Close
		Catch
				oWrite.Flush()
				oWrite.Close
		End Try
	Else
		For Each oRefDoc In oDoc.ReferencingDocuments
			RecurReferencing(oRefDoc, oStr, Level + 1)
		Next
	oEnd :
End Sub
Function DocNameWExt(oName As String)
	oPos = Len(oName) - InStrRev(oName, "\", - 1)
	oNameWExt = Right(oName, oPos)
	Return oNameWExt
End Function
GOAL:
1-702597.ipt -> 2-700287.iam -> 2-700294.iam -> 2-700296.iam -> 4-700150.iam
1-702596.ipt -> 2-700287.iam -> 2-700294.iam -> 2-700296.iam -> 4-700150.iam
1-702595.ipt -> 2-700287.iam -> 2-700294.iam -> 2-700296.iam -> 4-700150.iam
1-702594.ipt -> 2-700287.iam -> 2-700294.iam -> 2-700296.iam -> 4-700150.iam
1-702592.ipt -> 2-700287.iam -> 2-700294.iam -> 2-700296.iam -> 4-700150.iam
1-702593.ipt -> 2-700287.iam -> 2-700294.iam -> 2-700296.iam -> 4-700150.iam
1-702604.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
1-702601.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
1-702600.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
1-702599.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
1-702598.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
1-702574.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
1-702573.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
1-702572.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
1-702571.ipt -> 2-700285.iam -> 2-700296.iam -> 4-700150.iam
(sorted if possible)
___________________________
felix.cortes5K3Y2
Replying to follow the post.
machiel.veldkamp
Sub Main()
	'oTextSave = "C:\TEMP\iLogicBuffer.txt"
	oBOM = oCD.BOM
	oBOM.StructuredViewEnabled = True
	oBOM.StructuredViewFirstLevelOnly = False
	Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
	Dim oBOMRow As BOMRow
	Dim oCompDef As ComponentDefinition
	oWrite.WriteLine("__THIS IS A INDEX FOR: " & DocNameWExt(oDoc.FullDocumentName))
	oWrite.WriteLine("__")
	oWrite.Close
	Trace.WriteLine("**** Before FOR loop")
	For Each oBOMRow In oBOMView.BOMRows
		Call RecurseBOMRow(oBOMRow, oStr, 0)
	Next
	Shell("Sort " & oTextSave & " /O " & oTextSave, vbHide) 'TOGGLE ON OR OF DEPENDING ON YOUR WISHES
	Shell("notepad.exe /p " + oTextSave)
End Sub
Shared oTextSave = "C:\TEMP\iLogicBufferTest.txt"
Sub RecurseBOMRow(oBOMRow As BOMRow, oStr As String, Level As Integer)
	oCompDef = oBOMRow.ComponentDefinitions.Item(1)
	Dim TempDoc As Document = oCompDef.Document'.FullFileName
	Dim CurrentDoc As String = TempDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value 	'SHOW PARTNUMBER
	'Dim CurrentDoc As String = oCompDef.Document.FullFileName														'SHOW FILENAME
	If Level = 0
		oStr = DocNameWExt(CurrentDoc)
	Else
		oStr =   DocNameWExt(CurrentDoc)& " -> " & oStr
	If oBOMRow.ChildRows Is Nothing
		Try
			oWrite.Flush()
			oWrite.Close
		Catch
			Trace.WriteLine("Failed at level " & Level)
		End Try
	Else
		Try
			oWrite.Flush()
			oWrite.Close
		Catch
		End Try
		For Each oBOMRow2 In oBOMRow.ChildRows
			If Not oBOMRow.ChildRows Is Nothing ' Ooooh. Assembly.
				Try
					Call RecurseBOMRow(oBOMRow2, oStr, Level + 1)
				Catch
				End Try
		Next
End Sub
	Return oNameWExt
End Function
 Done.
