Need Inventor 2024 and 2025 API Object Model reference document
Aadithya01
Advisor Advisor
Aadithya01
Hi Guys,
I happen to find out that the Inventor API Object Model reference document is available only upto Inventor 2019. Can we get the Inventor API Object Model reference document for 2024 and 2025 version.
Thanks in advance.
WCrihfield
See attached for the 2024 version.  This same information can also be seen as an image within the online help area's documentation:
Getting Started with Inventor's API
, under the following category trail:
Programming Interface > Inventor API User's Manual > API Overviews > Getting Started With Inventor's API.
However, that image in the online help is not nearly as good of quality as the PDF document.  We all have access to that PDF document, after installing the 'Inventor SDK'.  Read the following online help page for more information about that.
Introduction to Using Inventor's Programming Interface
Once installed, it is within the:
C:\Users\Public\Documents\Autodesk\Inventor 2024\SDK\DeveloperTools\Docs\
folder.
I do not have 2025 installed at the moment, but I assume that would also be in the same place, after its SDK was installed.
Wesley Crihfield
(Not an Autodesk Employee)
pball
Here is the 2025 version. I have 2016 through 2025 if someone wants other ones.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
peter.roman
Here is the 2026 one from the Developer Tools SDK since I came across this thread while trying to find it
