Need iLogic - VB help to delete sheets from an .idw file...
JamesNordgren
Message 1 of 9
JamesNordgren
Can anyone help me with some code I can add to a drawing rule to delete a specific sheet from an idw file?
There is no direct command to do this in iLogic (2012 Pro - 64) so I am kind of stuck.  I know it can be done thru the API, I just dont know how to code it in an iLogic rule.
Thanks to Any who can help!
James
Accepted solutions (4)
Replies (8)
Message 2 of 9
Curtis_Waguespack
Hi JNORDGREN,
This should do it:
Dim oSheet As Sheet
Dim oListofSheets As New ArrayList
For Each oSheet In ThisApplication.ActiveDocument.Sheets
oListofSheets.add(oSheet.Name)
Next
Dim sSheetToDelete as String
sSheetToDelete = InputListBox("Select the Sheet to Delete", oListofSheets, oListofSheets.Item(0), "iLogic", "List of Sheets")
oSheet = ThisApplication.ActiveDocument.Sheets.Item(sSheetToDelete)
oSheet.Delete
If you get errors from copying and pasting directly from this forum, you can use the attached *.txt file.
 I hope this helps.
Curtis
Message 3 of 9
JamesNordgren
Thanks for the quick response Curtis (I had a feeling You wd be first to chime in on this)
I may be able to modify what you gave me to make work,  but how about this:  I dont need to get a list of the sheets and then select which to delete.  I want to delete specific named sheets based on other parameters, and with no user input.
In words, what I want to code is:
If "boolean parameter 1" = True
     Delete Sheet1
Else If  "boolean parameter 2" = True
    Delete Sheet2
... and so on like that.  Could you modify what you had written previously to work like that?
Thanks again
Message 4 of 9
Curtis_Waguespack
Hi JNORDGREN,
I don't follow how the boolean gets set without user input, but maybe this is something preset in a template or something? Here's an example with user input and a boolean:
Dim bSheetToDelete as Boolean
bSheetToDelete = InputRadioBox("Select a sheet to delete", "1st Sheet", "2nd Sheet", True, "ilogic")
Dim oSheet As Sheet
If bSheetToDelete = True Then
oSheet = ThisApplication.ActiveDocument.Sheets.Item(1)
oSheet.Delete
Else
    Try
    oSheet = ThisApplication.ActiveDocument.Sheets.Item(2)
    oSheet.Delete
    Catch
    MessageBox.Show("2nd sheet not found?", "iLogic")
    Return
    End Try
Here's an example that expects to find a preset boolean parameter named MyBooleanParam in the drawing file:
Dim oSheet As Sheet
If MyBooleanParam = True Then
oSheet.Delete
Else
	Try
	oSheet.Delete
	Catch
	Return
	End Try
 I hope this helps.
Curtis
Message 5 of 9
Curtis_Waguespack
If the sheet name is alway the same you could use something like this:
Dim oSheet As Sheet
oSheetName = "Sheet:2"
Try
oSheet = ThisApplication.ActiveDocument.Sheets.Item(oSheetName)
oSheet.Delete
Catch
MessageBox.Show(oSheetName & " not found?", "iLogic")
Return
End Try
 I hope this helps.
Curtis
Message 6 of 9
JamesNordgren
Thanks again Curtis,
Yes, the sheet name is a known constant, and the boolean for the IF statements is set by the user in a form which runs in an assembly rule.  Based on the options the user selects in the assembly, I want to delete certain sheets from a drawing.  I think I can get there now.
Message 7 of 9
To_Efficiency_and_Beyond
In our office, other departments sometimes access our inventor .dwg files using AutoCAD. If the AutoCAD user places a block in the model space tab and then saves, there will be a new sheet next time the file is opened in Inventor. This extra sheet wreaks havoc on soooooooo many processes. I want it gone.
I modified the first iteration of code posted above to delete a sheet with a specific name.
Dim oSheet As Sheet
oListofSheets.Add(oSheet.Name)
Next
Dim sSheetToDelete As String
sSheetToDelete = "Sheet Name"
oSheet.Delete
 First, I tested the code with a generic sheet name. It worked perfectly:
sSheetToDelete = "Model (AutoCAD)"
Then I substituted in the sheet name I really want to eliminate from all of my drawings:
This version failed. How do I get inventor to target this sheet?
Message 8 of 9
WCrihfield
Hi @To_Efficiency_and_Beyond.  I almost never work with DWG file type in Inventor, but I know of a couple properties and methods that you may find helpful.
When your code encounters a DrawingDocument object, and you need to test if it is a DWG type, versus an IDW type, you can use the following property to figure that out easily.
DrawingDocument.IsInventorDWG
When your code encounters a Sheet object, and you want to know if it represents a 'model space' sheet, you can use the following property to check that easily.   You may be able to use that while iterating all Sheets in the DrawingDocument, to find the sheet you want, even if you do not know the exact name of the sheet.
Sheet.IsModelSpaceSheet
When you have a DrawingDocument, and want to save it as DWG type, you can use the following method.
DrawingDocument.SaveAsInventorDWG
Wesley Crihfield
(Not an Autodesk Employee)
Message 9 of 9
Curtis_Waguespack
@To_Efficiency_and_Beyond , from memory, I think the only way to remove Model Space is to save the file as an IDW.
here is a routine to save the file out as a IDW and then save that IDW again as the DWG to strip the Model Space.
you can put it in a utility file ( ModelSpace Purger.ipt in the image below) and have the drawing open too, and run the rule from this utility file.
Dim oDoc As Document = ThisDoc.Document
Dim oList As New ArrayList
For Each xDoc As Document In ThisApplication.Documents.VisibleDocuments
	If xDoc Is ThisDoc.Document Then Continue For
	If Not xDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then Continue For
	oList.Add(xDoc.FullFileName)
Next
If oList.Count = 0 Then Exit Sub
oTargetDocName = InputListBox("Prompt", oList, oList.Item(0), Title := "iLogic", ListName := "List")
If oTargetDocName = "" Then Exit Sub
Dim oTargetDoc As DrawingDocument = ThisApplication.Documents.ItemByName(oTargetDocName)
hasModelSpace = False
For Each oSheet As Sheet In oTargetDoc.Sheets
	If oSheet.IsModelSpaceSheet Then
		hasModelSpace = True
Next
If hasModelSpace = True
	sName = oTargetDoc.FullFileName
	sName = Replace(sName, "dwg", "Temp.idw")
	oTargetDoc.SaveAs(sName, True)
	oTargetDoc.Close(True)
	Dim TempDoc As Document = ThisApplication.Documents.Open(sName, True)
	sName = Replace(sName, "Temp.idw", "dwg")
	TempDoc.SaveAsInventorDWG(sName, True)
	TempDoc.Close(True)
