Need iLogic rule to enter text to populate the same parameter in multiple parts
matthew_neesley
matthew_neesley
Hello to all:
I've tried to search for applicable info but not having much success.  I have a simple need:  I have multiple conveyor beds in an assembly.  There is a text parameter ("Speed") that is blank in the all of the parts' default configs.  I need an iLogic rule that will ask for a string of text and then push that string to ALL of the Speed parameters in all of the parts.  Can someone help me out here?  Thanks very much in advance!
matthew_neesley
I have tried this and no dice...
iLogicVb.UpdateWhenDone = True
Dim refDoc As Inventor.Document
Dim oDoc As Inventor.PartDocument
Dim oParams As Parameters
Dim oParam As Parameter
For Each refDoc In ThisApplication.ActiveDocument.AllReferencedDocuments
	oDoc = refDoc
    oParams = oDoc.ComponentDefinition.Parameters
	Try
		oParam = oParams.Item("Speed")
		oParam.Expression  = "120FPM"
	Catch
		'catch and ignore any errors
	End Try
Next
chandra.shekar.g
Autodesk Support
Autodesk Support
@matthew_neesley,
Try below iLogic code to update parameter (Speed) in all parts (not included sub assembly). If "Speed" parameter does not exist, code will skip that part and move to next.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oAsyDef As AssemblyComponentDefinition
oAsyDef = oDoc.ComponentDefinition
Dim oReferDoc As Document
Dim occ As ComponentOccurrence
' Get all of the leaf occurrences of the assembly.
Dim oLeafOccs As ComponentOccurrencesEnumerator
oLeafOccs = oAsyDef.Occurrences.AllLeafOccurrences
For Each occ In oLeafOccs
	Call occ.Edit
	oReferDoc = occ.Definition.Document
	Dim oDef As ComponentDefinition
	oDef = oReferDoc.ComponentDefinition
	On Error Resume Next
	oParam = oDef.Parameters.Item("Speed")
	oParam.Value = "120RPM"
	Call oReferDoc.Update
	Call oReferDoc.Save
	Call occ.ExitEdit(kExitToTop)
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
matthew_neesley
Ahhh....hmmmm...yes it looks like it "technically" works; but I guess i shoulda mentioned that I'm using Factory Assets.  What your code is doing is writing the text into the asset definition itself, so every time I pull in a new asset, it has this info hard-coded in it.  I'll post about this in the Factory Utilities board, but thanks again for your help!  Seeing this process actually has alerted me to how assets can inadvertently be changed in ways we don't expect.
