Need iLogic for Model sketch auto Constraint
gparamasivam
gparamasivam
Hi all,
Please see the attachment.
Currently i am using the below iLogic rule for deleting the horizontal and vertical constraints in model sketch.
Dim oPartDoc As PartDocument
Dim oSketch As PlanarSketch
Dim geoconstraint As GeometricConstraint
On Error Resume Next
oPartDoc = ThisApplication.ActiveDocument
For Each oSketch In oPartDoc.ComponentDefinition.Sketches
For Each geoconstraint In oSketch.GeometricConstraints
	If geoconstraint.Type = kHorizontalConstraintObject Then
		'MsgBox ("Deleting Horizontal Constraints")
Call geoconstraint.Delete
Else If geoconstraint.Type = kVerticalConstraintObject Then
			'MsgBox ("Deleting Vertical Constraints")
Next geoconstraint
Next oSketch
MsgBox ("All Horizontal and Vertical constraints deleted!")
But we need to after deleting the horizontal and vertical constraints, the sketch line should be auto constraints by using the XY master Plane (Projection line) or XZ master plane (Center line) arrest with parallel or perpendicular constraints
Hope you understand...
JhoelForshav
Hi @gparamasivam
I think I understand what you're asking for. Assuming all horizontal constraints should be replaced by parallel constraints to XY-plane and all vertical constraints should be replaced with parallel constraints to the XZ-plane this should do it 🙂
Dim XZPlane As WorkPlane = oPartDoc.ComponentDefinition.WorkPlanes("XZ Plane")
Dim XYPlane As WorkPlane = oPartDoc.ComponentDefinition.WorkPlanes("XY Plane")
	Dim oLineXZ As SketchLine = Nothing
	Dim oLineXY As SketchLine = Nothing
	For Each sLine As SketchLine In oSketch.SketchLines
		If sLine.ReferencedEntity Is XZPlane Then oLineXZ = sLine
		If sLine.ReferencedEntity Is XYPlane Then oLineXY = sLine
	Next
	If oLineXZ Is Nothing Then oLineXZ = oSketch.AddByProjectingEntity(XZPlane)
	If oLineXY Is Nothing Then oLineXY = oSketch.AddByProjectingEntity(XYPlane)
		If geoconstraint.Type = ObjectTypeEnum.kHorizontalConstraintObject Then
			Dim oLine As SketchLine = geoconstraint.Entity
			oSketch.GeometricConstraints.AddParallel(oLine, oLineXY)
		Else If geoconstraint.Type = ObjectTypeEnum.kVerticalConstraintObject Then
		oSketch.GeometricConstraints.AddParallel(oLine, oLineXZ)
	Next geoconstraint
Next oSketch
MsgBox("All Horizontal and Vertical constraints deleted!")
gparamasivam
Thanks for your quick solution,...
