Need a rule to run a program in derived part.
Hi All,
By using a ilogic rule I created a derived part from an assembly.
Ilogic rule used is mentioned below.
Try
    Dim g_App As Inventor.InventorServer = ThisApplication
    Dim AssDoc As Inventor.AssemblyDocument= ThisDoc.Document
    ' Create a new part document that will be the shrinkwrap substitute
    Dim oPartDoc As PartDocument
    oPartDoc = g_App.Documents.Add(DocumentTypeEnum.kPartDocumentObject, , True)
    Dim oPartDef As PartComponentDefinition
    oPartDef = oPartDoc.ComponentDefinition
    Dim oDerivedAssemblyDef As DerivedAssemblyDefinition
    oDerivedAssemblyDef = oPartDef.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(AssDoc.FullDocumentName)
    ' Set various shrinkwrap related options
    oDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsMultipleBodies
    oDerivedAssemblyDef.IncludeAllTopLevelWorkFeatures = DerivedComponentOptionEnum.kDerivedExcludeAll
    oDerivedAssemblyDef.IncludeAllTopLevelSketches = DerivedComponentOptionEnum.kDerivedExcludeAll
    oDerivedAssemblyDef.IncludeAllTopLeveliMateDefinitions = DerivedComponentOptionEnum.kDerivedExcludeAll
    oDerivedAssemblyDef.IncludeAllTopLevelParameters = DerivedComponentOptionEnum.kDerivedExcludeAll
    Call oDerivedAssemblyDef.SetHolePatchingOptions(DerivedHolePatchEnum.kDerivedPatchNone)
    Call oDerivedAssemblyDef.SetRemoveByVisibilityOptions(DerivedGeometryRemovalEnum.kDerivedRemoveNone)
    Dim oDerivedAss As DerivedAssemblyComponent
    oDerivedAss = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef)
    ' Save the part
    Dim partname As String=ThisDoc.PathAndFileName(False)& ".ipt"
    ThisApplication.ActiveView.Fit
    ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
    Call oPartDoc.SaveAs(partname ,  False)
Catch ex As Exception
        ErrorMessage = "Error creating ipt file."
End Try
After creating derived part, I want to run the below program automatically in the derived part.
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oAxis As WorkAxes
Dim oWPlane As WorkPlane
Dim FlatAngle As Double = Math.PI / 6
Dim NoSides As Integer = 12
Dim oSketch As PlanarSketch
'initialize counter
Work1 = 1 ul
Work2 = (NoSides / 2 ul) + Work1
oAxis= oDef.WorkAxes
oWPlane = oDef.WorkPlanes.AddByLinePlaneAndAngle(oAxis("X Axis"), oDef.WorkPlanes("XZ Plane"), 0 deg)
oWPlane.Name = CStr(Work1) & "-" & CStr(Work2) & " Plane"
Dim oWPName As String = oWPlane.Name
oWPlane.AutoResize = True
oWPlane.Visible = False
oSketch = oDef.Sketches.Add(oWPlane)
    oSketch.Name = "My_Sketch" & oWPName
    oSketch.ProjectedCuts.Add()
	oSketch.Visible = True
InventorVb.DocumentUpdate()
For Work1 = 2 To NoSides
	oWPlane = oDef.WorkPlanes.AddByLinePlaneAndAngle(oAxis("X Axis"), oDef.WorkPlanes(oWPName), FlatAngle/2)
    oWPlane.Name = CStr(Work1 + NoSides) & "-" & CStr(Work2 + NoSides) & " Plane"
	oWPName = oWPlane.Name
Next
JhoelForshav
Hi @Anonymous
You could create a template with the rule inside it and use that when creating your part. Then execute the rule from main assembly code with
iLogicVb.Automation.RunRule(oPartDoc, "rulename")
Or you could create the rule in the part from main assembly code
Dim oRule As iLogicRule = iLogicVb.Automation.AddRule(oPartDoc, "PartRule", "Rule text")
and then execute it as described above.
To create the new part from a template simply use the optional argument TemplateFileName in the Documents.Add-function 🙂
